I'm supposed to believe that this oil, under these conditions produced reduced wear rates compared to your other samples that apparently were subjected to more favorable weather conditions?quote:
quote:
My mom's Impreza had zero problems starting or running last winter when the temperatures were down to 0'F and slightly below overnight. That was using Motorcraft 10w30. No unusual noises or anything.
Yeah, starting is one thing - but increased wear is another.
Originally posted by vvk:
Funny you should mention it. I did oil analysis to check that very thing:
Motorcraft 10w30 below zero UOA
With all due respect, a typical UOA doesn't prove very much in this situation.IMO
"Scuffing" caused by insufficient lubrication(heavy adhesive wear) is more likely to produce particles in the 50-200 micron range.JMHO
Yeah, but that's with fresh oil, how about after there's some miles on it. I doubt it would perform nearly as well.quote:
Originally posted by Dr.T
In either case, I thought that a 10W was SAE certified to pump down to -25C and a 5W down to -30C. Is this not correct?
