Originally Posted By: garlicbreadman
Originally Posted By: Brenden
You should consider yourself lucky with a Honda/Acura engine with 200k on it that burns that little of oil, I am somewhere around 1qt for ever 1.5k miles at 207k with a suspicion of some neglected oil changes, but none the less unless you have owned the car since new and babied it for a Honda/Acura you shouldn't worry.
Use what ever you want and just chalk the 1qt every 5k up as a add pack refresher
10w will not stop consumption any better than a 5w
my friends 94 integra has 270k and does not consume any oil. he uses castrol gtx 10w30
All engines consume oil, whether you can notice it in a typically short OCI is something else. A lot depends on how the engine is driven; lots of high rev's usually increases oil consumption.
Anyway 5,000mi/gt is perfectly fine and no remedy is required.
Having said that, a 5w30 synthetic will have less oil burn off than an antiquated 10w30 conventional.
Any 5w30 syn' on sale is what I'd suggest.
