100% Random Pictures
Does that Liquid Wrench work pretty well? I’ve never used it but it is always highly recommended by people I know. I use PB Blaster, CRC Freeze Off and CRC Knock’er Loose.
I'm no professional by any means, so I did not use it extensively but on a couple of occasions and it helped me greatly; as you may already know, many mechanics are swearing by it
I’ll have to try it sometime it’s always the cheapest one lol. The worst for penetrating is WD40 that stuff isn’t penetrant it’s a lubricant lol 😂 and it is not good for penetrating at all.
Oldie but a goodie.
It's not a good lubricant either. Its primary purpose is water displacement, hence the name, WD-40, Water Displacement formula #40.
True. It does displace water nicely. I use it to spray in the floor of the beetle under the backseat since the window leaks and gets the battery tray wet so I spray WD40 on it and wipe the water away.
