1.8 Toyota or 2.4 honda
I haven't owned either engine in a car before but I am genuinely curious if you had to pick an engine you preferred which would you take? Any short comings with either engine?
The Toyota 1.8 from early 2000s and the k series 2.4 from the same time period
Until about 2003 the 1zzFE (1.8) was an oil burner because of sticking rings IIRC....Toyota fixed the issue and it became a long lasting and reliable engine.
I agree with your statement.
Although, out of the 3 1zzFE’s that I own, the 2006 and the 1999 use hardly any make-up Oil during its OCI……….the 1998, well that’s another story😊
The Honda k24 is a notorious oil burner with stuck or clogged rings as well. Great engine. Easy to maintain and work on otherwise.
Had a 2007 with 386000 miles on it and did not burn oil or had stuck or clogged rings either... Best Honda engine I ever had... My 21 HRV has the 1.8.. It is OK but not much power... I wish the 2.4 was in it instead...That was a great engine...IMO
There‘s both in my family, my son’s ‘07 Accord K24, and three 1ZZFE 1.8s, ‘06 Matrix, ‘07 Matrix, my ‘07 Corolla-none of them burn any oil between OCIs! The Corolla just cracked off a 302 mile workday subbing for the Transit (getting new brakes), another 38 MPG mostly highway run with me & around 500 pounds of tools, refrigerant, & parts evenly distributed throughout. 167,000 miles now, still running pretty much perfectly.
  • Like
Reactions: hrv
Both are good stuff.
What kind of cars are you considering? The 2.4 was installed in bigger cars, while the 1.8 was relegated to smaller ones.
The Matrix/Vibe is an awesome car. Small and good on gas, but with lots of space inside. You might also like the Echo, with its 1.5L I4 . Small on the outside, as much room as a Camry on the inside (due to being tall). The first-gen Scion XB and XA are both based on the Echo.
My choice would be the Matrix XRS or Vibe GT with the 2ZZ-GE :D
That is a different engine than the 1ZZ-FE that you are probably referring to.
To me, modern engines have GDI, maybe a turbo, dual VVT, cylinder deactivation, etc. 🤯
all the stuff BITOG hates 😂
