- Joined
- May 21, 2023
- Messages
- 6
https://share.icloud.com/photos/0e7dho4sGWIUUnq1iBNwrMG1QWhat is this sound? No check engine light runs fine ruled out internal engine issue. Only at Idle after warmed up it goes away once in drive or reverse? Almost sounds like exhaust cooling or bad bearing. I’m baffled and trying to save a couple hundred it’s on passenger side under engine or an accessory. Car has 55k
