Good question, will they perform the same in summer months?
-John
-John
Yeah. True. Though some synthetic oils do use VIIs, perhaps a 5w40 or 5w50. But most synthetics should be pretty sheer stable. If I could run a 5w40 that had no VIIs I might do it, but it probably would be the cost-prohibitive Redline oil.quote:
Originally posted by kickster:
Assuming all these oils are synthetic then the VI sheering should not be a factor!
Exactly, we've got GC 0w30 which shows itself not to thin out very easily, except perhaps in turbo applications. In my old LT1 Firebird it would actually thicken up instead of thin out.quote:
It appears that it uses very little, if any. Although it would be nice if we could get the full in depth voa on this stuff!quote:
Originally posted by JohnnyG:
OK then, what's the story on GC? Does it have a lot of VII's or not? Final answer?
How much would it cost and how would you get that done?quote:
GC!quote:
All conditions equal, and changing the oil religiously every 3000 miles, which Mobil 1 weight would theoretically be best for the engine:
0w-30
5w-30
10w-30
Thickening is not good either and is an indication of a lack of high temp stability based on what I've read.quote:
