Originally Posted By: SavagePatch
Can a 0w30, say Mobil 1 not Castrol Edge, be safely used in place where a 5w20 is called for? The specific engine is a Ford 3.7L V6 Duratec. If yes, would the 0w30 protect significantly more. Conditions are short tripper, stop and go in Northern California.
Thanks in advance!
and I want to piggy back off your question by also asking the same question pertaining to 5w-30 to 0w-30. If a car is "perscribed" 5w-30, would using a 0w-30 give me any gains if the use is in SE texas where it is hot 8 out of 12 months but right now is very moderate in 60-70s. My hashed out thoughts are if wear happens during startup then anything that is 0w versus 5w should flow faster during startup regardless of whether you are in a constant hot climate or if it moderate to cold.
