0w0 oil for sale?
so my way of observation, the 0w/0w would need be of a consistent viscosity at a fixed temperature or a constant,
Every oil is a fixed viscosity at a fixed temperature.
and would not change with raising the temperature or lowering,
No oil could behave that way. Viscosity always will change with a temperature change.
... also the hths and other testing procedures may not exist or be meaningly useful, as its currently used on other lubricants of thicker viscosity's, so in other words the zero viscosity verses zero may need a new way of measurement of itself. (pascals),,in the lubricant world.
As long as an oil has a viscosity, which they all do regardless of how thin they are, the viscosity and even the HTHS viscosity can be measured.
A "0W-0" would not be "zero viscosity". The second "0" would have to be defined as some viscosity grade, just like all other motor oil viscosities have an associated grade.
But there is more likely to be a xW-4 and xW-2 before getting to xW-0 (which I don't think will ever happen).
Yes, and they would all have to be defined with a KV100 less than a xW-8, in respective decending order.
Yep, the issue is, that with SAE 0 not being defined, like with SAE 5 also not being defined, when companies make up oil grades and slap them on a bottle, they don't care that there is almost assuredly an existing SAE grade that applies. IIRC, one of the ones that was labelled as "0W5" was actually a 0W-12, another was a 0W-20.
"Back in the day" there were monograde Winter oils. You could buy SAE 20W for example, and other exciting grades like 10W-20W-40:
If we go by J300:
An SAE 0W would need to have a CCS of 6,200cP or below @ -35C, an MRV of 60,000cP or below at -40C and a KV100 of 3.8cSt or higher. They can ignore HTHS.
There is no SAE 0 grade, so no. It doesn't exist in J300.
You could make an SAE 0W by not testing it for hot viscosity, but that would be a bit stupid in this day and age.
And since it doesn’t exist as a standard then anyone can define it however they wish. One is this way and another that.
X
If we go by J300:
Wasn't there an oil with no vm in old days? Straight 20 or something like that. Is that the one in your post? I recall Shannow talking about it.
It appears that this website is selling "0w0" motor oil.
I could not find any MSDS sheets or specifications on the website, so it makes me a little suspicious.
To the tribologists here, is 0w0 oil possible?
https://cermatreatment.com/blogs/news/synthetic-oil-cerma-evo-0w0-motor-oil
https://cermatreatment.com/products/evo-synthetic-motor-oil
AFAIK 0w8 is the lightest oil available now. Is there anything else lighter out there?
That’s as far as they can take it……unless we get a 0w negative 5 oil….
X
Any oil without VII's can be labelled a monograde or a multigrade, so a 10W-20 for example with no VII's could be sold as an SAE 20. AMSOIL used to sell a 10W-30/SAE 30 that was formulated in this manner. The entire HPL No VII lineup is this way, they could all be sold as monogrades.
You can see the one example I posted was only Winter rated, just SAE 20W no hot grade.
That right. What would be the defined 100C viscosity for the grade after the W? It is certainly not defined in any SAE classifications.
A 0W8 oil is already down to 5 cSt at 100C.
Sorry, I can't tell if you are agreeing with what I said or not.
As far as I can see the numbers to the left of the W are not linear nor have a solid value at "0". The numbers to the right seem to be a little more defined and linear but not with a solid definition. If they keep using whole numbers there is not much more room to invent new viscosity of oil without overlap or moving the scale.
I could also be talking out of my butt as my mind has way too much free time lately.
It's all defined by SAE J300, as shown in post 27. The W grade ratings are defined differently than the hot KV100 and HTHS side of a multi-grade oil. Multi-grade oils can only fall into one W grade and one KV100 grade as defined by J300.
