I just finished rereading all the old posts on what weight oil to use. Finally got my new 302 efi roller engine installed and running in my 65 Mustang. I understand the break-in methods and the 10 psi per 1000 rpm thinking. I have decided to run a 0W20 oil after the short initial break-in. From my limited understanding the 0W is for cold starts. Does this apply to the hot months also? Still a 0W oil for year round use? At 2,000 rpm I should have 20 psi, but at idle I will have less than 10 psi. Is this enough to keep the engine from excess wear? Do i run the same weight when I ocasionally take it to the strip or autocross?
Thanks
Thanks
