0W oil in new engine
IMHO Rotella T6 5W-40 Synthetic would be the perfect oil for that engine. With it, you wouldn't have to worry about changing oil types for street or track use.
There is no way I'd run 0W-20 in that engine. No way.
I'd see how a 10w30 HDEO - Rotella, Delvac..etc...works in it.
If you really want to run a synthetic, Rotella 5W-40 or Mobil 1 0W-40 would be good options.
So often people say that an engine from the past, say 1980, required a 10w30 oil and therefore today we should use that exact same oil. Others even say that the oil was SE API rated and therefore that's what should be used today. Some complain about the difficulty on obtaining those SE oils as "required" by their engines.
My feeling is that some are stuck in the past and have little knowledge of the API ratings and their meanings. And is oil of today no better than from 40 years ago?
My thinking is that todays oils are far superior than those of the past. And that using the 10 PSI/1,000 RPM "rule" is a good ball park as to where to begin thinking about the appropriate viscosity for the job. I also believe that using an oil that is a grade thinner than you might at first think is most likely safe for most engines. And maybe better than using one a grade thicker.
aehaas
aehaas
The engine in question doesn't have what most would call a rigid bottom-end (I have a lot of experience with 302's). Thin-wall castings, thin main-webbing....etc. But it DOES have a good oiling system!
Why do I mention this? Well, when you have a non-deep skirt block like that of this Windsor, under high load and RPM, things move around. And because things move around, you may need a little more "cushion" there then what you would need at the same power level in the same engine with a more rigid bottom-end setup..... Like say a Ford Motorsport "R" block, BOSS 302 block, Dart block....etc. Which all have heavily beefed up main bearing areas, 4-bolt main caps....etc.
One of the things Ford did when they migrated from the SBF to the Modular was to heavily strengthen the bottom-end, making it FAR more rigid. The main-cap area on a Modular doesn't move. This was part of the reason Ford was able to specify the 5w20 grade going forward. Of course this was also in conjunction with a more modern, much higher volume gyrator-style oil pump instead of the standard cam-driven gear pump found in the Windsor engines it replaced.
I'm not telling him to run 20w50 (though there'd be plenty of Windsor guys who would), but I think stepping up to something like Mobil 1 0w40, particularly if he has a stock-volume oil pump in an engine that has upgraded heads/cam/intake, is a wise choice based on how I've seen it perform in this application.
Thanks to everyone for all the info. It is most helpful for a real novice that never questioned oil usage before finding this sight last year. I should have supplied a little more info. The engine was a 1993 302 EFI GT engine that was in a 93 GT that was never titled or put on the road. It had less than 200 actual miles on it. Pistons were not even black on the top and oil looked like new. I decided to not touch the bottom end for now. The engine has Trickflow aluminum heads, 1.6 roller rockers, Comp .512 lift cam, Trickflow intake and plenum, BBK 75mm throttle body, BBK cold air intake, 24# injectors, MSD ignition, Meling high volume oil pump, 5-speed, and 3.92, 9" posi-rear and many suspension mods but that does not affect oil usage. I am sure I can think of more but that is enough to get the picture. Does that change the basic premise? I am leaning toward Amsoil 0W or 5W30 now to start with (no I have never used a synthetic nor Amsoil so let me know about this, also). I have way too much invested and am trying to learn something to help it run a little longer. I really apprecaite all of your comments and time so if you have any more to add with this info, please do. I have a new Dakota digital dash so oil pressure guage is very precise.
I really doubt you'll have less than 10 psi at idle with that Melling HVOP, much less only 20 psi at 2000 rpm. Heck you could probably run straight ATF and get higher numbers than that with that pump (Don't!).
Since you have that good guage set, I say try a 5W20 or 0w20 oil. You might like it. You can always change back to something heavier if needed.You'll probably want to go for a couple of long drives to see what the oil pressure settles down to. Especially before heading to the track.
The HV pump is a waste IMHO, unless you have a blower to feed (which you don't). They simply don't need them.
That being said, my recommendation for Mobil 1 0w40 still stands for this old Windsor.
aehaas
Very informative post.
If it was mine I would run 10w30 hdeo.
On a beat on it Hi Po engine, Mobil 1 0W-40 all the way...
So it's a little thick when not to temp, they'll be plenty of times oil will be at 210* and engine spinning at 6000+(at least that'd be the case if it were mine)... As Overkill pointed out the crank and block will be flexing a bit, and I agree with having the extra protection...
I ran a bunch of 20W-50 in the 5.0 in my '88 T-Bird(hey it was free), after 700+ drag strip passes the engine finally succumbed to a blown head gasket... Guess I should blame that on the oil? I'd rather think the 150Hp shot of nitrous had a larger part in this picture... Not going to fix it, time for something bigger and better...
Originally Posted By: 1965Mustang
From my limited understanding the 0W is for cold starts. Does this apply to the hot months also?
0W applies to cold starts when it's below freezing. At warm temperature but with engine "cold", 0W-20 and 5W20 should have similar viscosity. W is effectively Winter rating. In fact, 0W40 should be thicker than 5W20 and 5W30 at say 30-40C even though it has 0W in its rating.. The only point of 0W20 is to have good year around protection. It is more or less superfluous if you live in a state with warm winters.
If you want to use Amsoil, the 5W-40 AFL is a light 40 grade like Mobil 1 0W-40. A robust 30 grade is the diesel 5w30 HDD.
-Dennis
Thanks to everyone for all the info. Very informative and a lot of helpful info. One thing seems to be common-since I live in NC it is not absolutely necessary to run 0W. 5W should be sufficient if I read correctly. I think a lot of you feel the 10 psi rule is fairly good but as one of you said for a little more protection go up a weight. Yes, I run it hard so I think I am going to try either 0W30, 5W30, or 0W40 since Overkill seems to be very familiar with the 302 bottom end construction and limitations. Thanks again to everyone for all the info. Your input is much appreciated.
aehaas
Excellent and informative explanation. You seem to have a lot of experience with sb Fords. I wanted to clarify one point you made to see if you think I should run 0W30 instead of 0W40. I have a Meling HO oil pump, not stock. Also the car is never started outside or left outside to get cold. I live in NC, also. Do you still feel a 0W40 is the best choice? I drive it very hard. When I talked to the tech at Amsoil he recommended a 0W30 but you seem to have more first hand experience with small blocks. One last question, why do you feel a HO oil pump is not a good investment? I put in in for just that reason, extra insurance. Thanks again for all the info.
Peronally,I'd sleep just fine with a 5w30 or 0w30 weight oil in this motor. Know alotta mustang freaks from old to new mustangs,and gotta say,the majority run between a 0w30 to as thick as 10w30.
aehaas
The reason I recommend the 0w40 is because it is a more robust formula than the 0w30 and designed (and certified) for high power density applications.
The 302 is not susceptible to lubricant-related failures with the stock volume oil pump. It has an excellent stock lubrication system that needs no improvement in the vast majority of applications. Even used for road racing, typically all that is upgraded is the oil pan to a baffled and larger capacity version.
The idea that it needs an HV oil pump stems from the same school of thought that it needs 20w50. That "more" is "better". Then you end up with guys needing the hardened ARP oil pump driveshaft because they licorice-sticked their stock one trying to pump 20w50 through an engine designed for a 30-weight with a pump displacing twice what the stock one did.
What the HV oil pump does is spend more time in bypass, dumping oil back in the pan, robbing power and wearing your cam and distributor gears, subsequently throwing off your ignition timing.
About the only time (IMHO) than an HV pump makes sense is if you are running a supercharger that doesn't have a stand-alone lubrication system. The engine (and its lubrication system) was never designed to feed anything beyond what it came fitted with. So tapping into that system to feed a blower steals volume from the rest of the system.
The other thing about a blower is that it heats the oil. A LOT. And the guys I know step up into a 15w40/5w40 or even a 5w50 to keep their hot oil pressure in the 30's when running something like an S-trim with a stock pan. With a larger aftermarket pan, this is likely not necessary (the heavier grade).
Now Mobil 1 0w40 is a VERY light 40-weight, almost a heavy 30. So it isn't like you are stepping up into 20w50 land here. You are going just a touch heavier than what the engine called for (10w30) stock, with a more robust additive package, better base stocks and a huge host of testing/certification for extremely high power density euro applications. You simply can't go wrong with it here.
ford has back spec many of the latter 5.0 efi's i have a 93 t-bird w/5.0 ho and father-in-law has a 93 foxbox 5.0ho both with over 150k both are also back speced for 5w-20 used by ford. i have mobil super 5w-20 in the t-bird. no change in oil pressure, the up side is quick pressure up(40psi before the engine even fires) and way quieter valvetrain(lifters).
Yours are stock however, correct? The OP's engine isn't stock, and is likely making a good 100+HP over stock.
