i wouldnt use anything less than 5w-xx.
you may be burning some oil until the oil reaches operating temps if you use mobil 0w40.
you ll be fine with a strong 5w-xx oil.
Huh???? You do realize your comment makes no sense right?
The oil is a 40-weight (albeit, a light one). But it has superior cold flow to a 5w, 10w, 15w, 20w 40-weight oil.
It doesn't flow like water at -30...... It is still heavier than spec for a 40-weight at any temperature below 100C.
i just assumed it s a high mileage stock 65 engine and he is switching from 15w40 to 0w40. and i missed "loc:texas". so he isnt seeing low temps. sorry for the misdirection
Hey, no problem. It'll be lighter at start-up temps, but still is a 40 hot. I figured you may not fully understand the grading system, which is why I pointed out what I did. Wasn't trying to be rude, so I hope I didn't come across that way.
