Originally Posted By: JHZR2
Originally Posted By: Danno
With almost 4000 posts and you haven't heard of 0W-16? It's probably been talked about for at least 3 years on this forum. To give you a preview, your next Camry will probably use 0W-12.
Congrats on the new ride sounds sweet.
I was going to put it a little bit more politely, but yes, there is a lot of discussion on 0w-16 and lower grades on here. Probably very few adopters.
Apparently my Honda Accord Hybrid is back-specified to run 0w-16. Im more hesitant in that because when highway driving, the engine will randomly shut off after going 10 miles at 75 MPH - so heat soak and resultant even lower viscosity is a concern.
For a regular IC engine specified for this oil, Id have fewer concerns if any.
When the engine shuts off, does the water temp go up? When the engine is shut off the vast majority of the oil is down in the pan and doesn’t see any additional heat. In fact you would have shut off the source of hot oil to the pan so it would instantly start cooling off from air flow across the pan. Just an alternate angle.
Fine point, perhaps a bit OT for this thread, but Im sure youre right. Just like an operating engine has the bulk of oil in the pan. My concern is the oil trapped between the piston and the block, and the oil in the bearings. Id suspect that heat will readily transfer into that oil, raise the temperature readily, etc.
And certainly a good reason to have a synthetic oil in those spaces.
