I just bought a 09 Ranger 4x4 5 speed for my wife...I'm not a Ford guy and bought it because it's very clean and appears to have been maintained...It has the 4.0 SOHC engine, 93,000 miles...The earlier 4.0 SOHC was noted for timing chain wear issues, very expensive because the engine needs to be pulled to replace the odd rear chain......Supposedly Ford revised the cam chain drive around 2006 to eliminate the complaints....
The engine runs very quiet cold or hot....Ford recommends 5-30 oil....Considering try to maximize cam chain life, what weight and type oil would you use? This truck will be used like a car and won't be normally towing a trailer... Thanks..
