I have a 2008 Tacoma PreRunner, with the 4.0 V6. The cap says 5w30. It just turned 110K miles. I live in a semi-rural area and 95% of my driving is hwy running 1900-2200 rpm. I have used Mobil 1 5w30and 5K oci starting with it's 1st OC until 80K when I started using Mobil 1 Extended Performance 5w30 and went to a 10K oci with a filter change at 5K. My confusion started with I read the Toyota Oil Chart and found out Toyota does not recommend synthetic oil for the 4.0L in a Tacoma, not even today. Yet, synthetic oil is fine for my wife's 08 4Runner with the same engine. I use Mobil 1 Extended Performance 5w30 in her car and she has over 120K with no engine problems.
What gives, why is synthetic bad for a 4.0L in a Tacoma and perfectly fine, even recommended for the same engine in a 4Runner? My little truck has always run fine on Mobil 1, the engine is smooth, quite and in 110L miles has only required routine maintenance. At oil change time the oil is slightly darker than new, but otherwise looks good. I am quite happy with M! and really don't want or plan on changing to a different oil. Is my engine running on borrowed time? Is it getting ready to explode or self destruct on me?
