07 Subaru Tribeca Pennzoil Plat 5W-30 6000 miles
Vermont
Another high copper late model Subaru report.
Code:
2007 Subaru Tribeca
Pennzoil Platinum 5W-30
Miles on vehicle: 18000
Miles on sample: 6000
Time on sample: ~6 months
Sample date: 7/4/08
Oil Filter: Supertech
Iron 13
Chromium 0
Nickel 0
Aluminum 5
Copper 98
Lead 1
Tin 0
Cadmium 0
Silver 0
Vanadium 0
Silicon 13
Sodium 5
Potassium 0
Titanium 0
Moly 111
Antimony 0
Manganese 1
Lithium 1
Boron 40
Magnesium 14
Calcium 2668
Barium 0
Phosphorus 674
Zinc 780
Fuel
Soot
Water
Visc@100 10.0
TBN 8.71
Oxid 13
Nitr 19
This is my mother's car, she drives it gently. It sees a lot of short trips to and from work, and might not get completely warmed up.
I wonder if the high copper has something to do with the variable valve timing hardware. This motor consumed zero oil in the 6000 mile interval.
Based on the TBN alone it looks like this oil could have gone a LOT longer in this car.
TBN of 8.71 after 6,000 miles?
Does your mom run it all day at 55 on the highway!
The copper is up there. Might be a trait for this type of engine, like the GM LS1.
With only short trips, and only 18k miles, most likely a combo of wear and break-in. Hopefully it will trend down in future UOA's.
Amazing TBN! Looks like it could have gone 12-15k miles!
Hopefully it is still from break-in, but it should have still been quite a bit lower than that IMO.
Did you search for any other H6 uoa's? What's in there now?
-Dennis
This Subaru has been fed a steady diet of Pennzoil Platinum and modest OCIs since my mom bought it with 11k miles. Right now I have a mix of 4 quarts 5W-20 and 3 quarts 10W-30 in there. I plan to sample the current batch at about 6000 miles.
As far as the TBN goes, this test was done by whatever lab Amsoil is currently using. I had another sample from my dad's Tundra with a TBN of 2.9 and they said the TBN was too low, so I guess their scale is different than Blackstone.
Haven't been able to find other flat six Subaru UOAs, but mostly because of the crummy search feature.
I didn't even think the TBN of PP was that high to start with, I thought it was 8.? Is that not the case?
