06 Legacy 2.5i: GC or PU for winter?
Metro Detroit, MI
1. 2006 Subaru Legacy 2.5i (52K Miles, Auto, Naturally Aspirated, stock)
2. SM/SL 5w30 but lists bunch of other weights up to 20W-50
3. Metro Detroit, MI. Winters can be 0-30 degrees Fahrenheit with lots of snow.
4. Moderate Driving. Redline a couple of times per day while driving
5. Work is 12-15 Miles away, 75% Highway 75-80MPH. Rural streets 45-50MPH.
6. No Problems.
Current fill is SynPower 5w30. Last winter was my first run of synthetic with QS UD 5w30. Already have a jug of Pennzoil Ultra 5w30 in the stash. Will probably be due for an oil Change around late Dec/early Jan. What would be better for winter German Castrol 0w30 or Ultra 5w30? Only issue during winter is a knocking noise heard when I first turn on the car in cold weather, goes away after warmed up a little which is a characteristic of the Subaru boxer engine I hear on the web. I park outside so sometimes it is covered in snow from an overnight storm. I would buy the GC when Autozone/Pepboys put it on special again as both around here carry it all the time.
I've used GC for eight Chicago winters in a Toyota without incident. Having said that, I would think the Ultra has better cold temp properties and would use that in your situation.
(In the correct grade).
my 2.2L loved the slightly thicker side in DC area. 10-30M1 year around. 5-30 would shear and get noisy by 2500 miles. I ran 10,000 OCI and never had any problems. I dunno if I'd worry about getting the thinnest oil. I think either choice would be fine, but also that piston slap, which mine had too and never caused any problems, would be a little happier with the slightly thicker oil.
