Pabs,
I looked at those UOAs you mentioned...the Pennzoil was a SL formulation and the Clean 5000 was obviously a SM formulation...the Clean 5000 stayed in grade better and delivered longer service life.
I don't understand why you're saying that 7500 would be a stretch...oil was in good shape flashpoint, TBN, vis, and insolubles wise with the Clean 5000...and could've made it another 2-3000 miles. Yes the TBN was 1.9...but this is on the wacked Blacksone scale, and like I said, would be reading >4 with the standard ASTM D-4739 protocol OAI uses; IIRC, cut-off for ASTM D-4739 is 1.0.
Explain to me what benefits synthetic oils would bring to this application under normal, daily driving conditions. Both oils will do the job, once for 50-70% less....Wear will be the same, any slight wear reduction synthetic may bring (which I highly doubt) will simply be considered "nitpicking" and is unlikely to affect the engine life significantly, as the engine should last well over >250,000 miles.
