I notice a buzzing vibration sound inside the cabin coming from the rear of my 05 Corolla. This has been bothering me for over a year now. I couldn't do anything about it due to the winter we had. The trunk was cleared out and made sure the spare tire was secure but that didn't help.
The rear drum brakes were cleaned and lubed last weekend but the buzzing noise didn't go away. I didn't disassemble the brakes. Just sprayed down the drums and brakes with Valvoline brake cleaner and used Permatex Anti-Seize on contact points. Lubed adjuster screw and adjusted rear brakes so they are snug to the drums but not tight.
The buzzzzzzing vibration is always audible between 20-25mph speeding up, slowing down, and cruising at that speed. Rarely it can be heard briefly at highway speeds. But its fine cruising at 35-40 mph in the city. It seems to be speed related, I can almost predict when the noise can be audible while driving based on the speed of the car. I was 90% sure it was the rear brakes because there isn't much back there that can make that noise. I'll try to record a video with my cell tomorrow but not sure if the microphone is sensitive enough to capture it. Your help is appreciated.
