Ok so about a week ago I accidentally take off without disengaging the parking brake. Made it to about 35-40 when I realized it and quickly stabbed the brakes before hitting the release. Since then I’ve had an intermittent squeal after parking the vehicle. It doesn’t correspond with using the P brake %100 of the time. Last week I noticed a fried electronics smell which Ive dealt with once before so after it was obvious the wires were fine, I realized there was smoke coming from the driver rear wheel. It went away but started squealing again last night. (Truck is 4 wheel disc)
Not %100 sure it’s the tophat/integrated parking brake system or the caliper. For one I still haven’t been able to remove the caliper. Used a C clamp to free up some slack and the caliper has slight movement but won’t pull off of the pads. The pads have clips not only holding them to the caliper but also appears to have clips at the top of each pad holding it there as well. Caliper doesn’t have a mounting bracket as it’s part of the axle and it looks like the caliper has interlocking teeth that also allow it to slide on “bracket”.
My doubts about the parking brake are based on the pads looking [censored] near brand new and sporting high end parts. (Rotors were Bosch Premium) but there’s rust all over the clips that the pads slide on and the bolts/pins were bone dry. No sign of grease being used anywhere. Spoke with my Grandfather who owns the Truck and he said a year or so ago they replaced the rear brakes at inspection and he never leaves town with the truck. 120xxx miles. I’ve had it since 117k while I putz along on my personal vehicle and It’s falling apart. I’ve driven it more in the past 4 months than he does in a year. He purchased it with a busted window motor, since then the other window just fell off the track when I hit a speed bump, a leak I thought I fixed 2 years ago came back and cost me $30 in hoses and fittings to fix, now the brakes aside from having to strip the driver floor and pillar trim to free a frozen seat belt.
Given the issues I’d like to remove this caliper without breaking anything, anyone got the proper method down pat?
