have a company pickup with 300k miles on the clock; not sure of all preventative past maintenance, but lets just say it only gets it when something actually fails.
Here's the dilemma, this problem has been on and off, it's not consistent.
One day it'll be hot outside, so i'll turn the dial to cool air or actually turn on the a/c; later that same day, I'll turn the heat on and the truck acts like it's stuck in a/c setting, you can actually hear the compressor kick on and I get cold air when the dial's set for heat.
This does not happen all the time, 90% of the time everything works as it should and I'll get good hot heat when needed.
Tonight it acted up and gave me cold air all the way home, one thing I noticed is when I turned the blower on or off, there was this crying type sound somewhere in the passenger compartment area.
temp gauge is normal, I'll double check antifreeze level in the morning, any ideas that I can resolve myself
