Below are the last 3 oil analysis reports on our 2003 Acura MDX which now has nearly 131,000 miles. The first two were done using Redline 5W-20 on the same oil, the first sample at 3000 miles and the second at 9100 miles. The third and last sample was done at only 2500 miles using Redline 2.5W-20 (2 quarts of Redline 5w-20 plus 2 quarts of Redline 0W-20). The numbers look considerably worse on the last sample.
Of still more concern, however, is the fact that all of these samples were taken after I noticed that the oil level was INCREASING during use. And we're not talking about only a slight increase--we're talking over a quart during the 9100 mile interval and over 1/2 a quart during the 2500 mile interval. None of the three samples gives any clear answer to me as to what the problem is. I suspect a head gasket mainly because it is losing coolant ever so slightly and is losing power and gas mileage is worse.
If any of these results give anyone any ideas on what this problem is, I would certainly appreciate it. Thus far, no one I've talked to has any idea on where to start.
Code:
oil Redline 5W-20 Redline 5W-20 Redline 2.5W-20
miles use 3000 9100 2500
miles unit 120,000 126,10 128,300
sample date 7/22/10 2/07/11 4/26/11
Lab used Analysts Oil Analyzers Same
IRON 3 16 8
CHROMIUM
NICKEL
ALUMINUM
LEAD
COPPER 4 10 5
TIN
SILVER
TITANIUM
SILICON 6 9 13
BORON 89 20 9
SODIUM 62 100 34
POTASSIUM
MOLYBDENUM 181 162 579
PHOSPHORUS 798 563 850
ZINC 935 710 975
CALCIUM 2123 1767 2074
BARIUM
MAGNESIUM 9 11 7
ANTIMONY
VANADIUM
FUEL 1.0% 2.2% 1.6%
WATER
VIS. 100 C 8.3 10.1 9.8
TOTAL BASE # -- 2.3 2.95
OXIDATION -- 31 53
NITRATION -- 22 23
Comments:
Sample 1 (7/22/10) moderately high sodium level noted but attributed to prior use of Valvoline Synpower.
Sample 2 (2/07/11) Viscosity is MODERATELY HIGH; FUEL DILUTION is at a MINOR LEVEL; Sodium is at a MINOR LEVEL; Lube oxidation may be increasing.
Sample 3 (4/26/11): OXIDATION is SEVERELY HIGH; NITRATION is at a MODERATE LEVEL; Viscosity is MODERATELY HIGH; FUEL DILUTION is at a MINOR LEVEL.
Code:
IRON 3 16 8
CHROMIUM
NICKEL
ALUMINUM
LEAD
COPPER 4 10 5
TIN
SILVER
TITANIUM
SILICON 6 9 13
BORON 89 20 9
SODIUM 62 100 34
POTASSIUM
ZINC 935 710 975
BARIUM
MAGNESIUM 9 11 7
ANTIMONY
VANADIUM
FUEL 1.0% 2.2% 1.6%
WATER
OXIDATION -- 31 53
NITRATION -- 22 23
Comments:
