Originally Posted By: pcfxer
Originally Posted By: JSRT4
I wasn't concerned with the viscosity issue here because my engine specs 10w30 or 5w40, so if it ended up being a 30 weight, no biggie. Plus every sample I've sent to CAT labs has alwaysm come back with viscosity numbers that were a good bit below the numbers you find on manufacturer spec sheets. I think it's partly the lab and the fact that Amsoil 5w40 is known to shear. This engine is also known for shearing a number of different oil brands/weights.
Yeah it sheared...so what? Oxidation and Nitration are low and the engine is alive...
JSRT4, that comment is directed more at previous statements. Can you get Toromont to run a TBN next time around? There is nothing wrong with the 5w-40, you could if you wanted continue running it. A few of my clients running K20s are enjoying the switch from 5w-40s to SSO 0w-30 though
Thanks for the reply on this. If I recall Toromont requires me to send them a virgin sample of oil in order for them to calculate TBN and that costs a few more bucks. I never ask for the info as I don't put more than 5k miles on this car a year and I know the oil is still plenty strong at the end of the driving season TBN wise.
Thanks for the tip on 0w30. I'm going to run a 30 weight Amsoil fluid next and see how it compares next season. I'll likely be using their 5w30, it seems to have a better viscosity number and NOACK number from what I can see. SSO does sound like a great oil too.
