Ex called me in a panic because his Accord died while he was driving. His brother looked at it and found the distributor cap was loose (because it was melted on the bottom) and attempted to replace it but they had got the wrong one from Autozone. I delivered the correct part but didn't bother trying to install it because there was a ton of oil coming out of the distributor so I figured it was bad. Towed the car to where I work, we bought a new distributor, and I installed it.
Unfortunately it still doesn't start. It'll crank and crank and crank but not even sputter or anything. It seems to be getting fuel, at least you can smell fuel under the hood after trying to crank it, although I haven't actually tested fuel pressure. I checked the spark by using a screwdriver shoved into a plug wire and the two cylinders I tested had spark.
After that I connected a scanner and found the following codes, which I then cleared and they didn't come back at least while cranking the car.
P1382 "Cylinder Position Sensor No Signal"
P1259 "VTEC System Malfunction"
P1164 "Primary HO2S (No. 1) Circuit Range/Performance"
P0336 "Crankshaft Position Sensor Range/Performance"
I immediately suspected the crank sensor however upon cranking the scanner shows about 150RPM so it seems to be working, and I believe the crank sensor is part of the distributor anyway so it should be good, it's brand new.
Some research online shows that the P1382 could be the PCM but I doubt the PCM and distributor failed at the exact same time. Any help appreciated! I'm wondering if all the oil that leaked out of the old distributor cap screwed something up. It got all over the sensor right under the distributor as well as all over that wiring harness.
Perhaps worth noting we changed the heater hose that connects right under the distributor about a week ago because the old one had a hole in it and was squirting coolant all over the bottom of the distributor and related area as well. Managed to wiggle the old one out and new one in without removing the distributor because we didn't wanna mess with the timing. For the new distributor I sorta just guessed on the timing, didn't actually check it, but I'm assuming it should still start anyway...
