I have a grizzly that sat for about 4 years. The Carb was all gunked up and it would not run when i got around to running it. I pulled the carb out, cleaned everything up and reassembled it. Now the ATV starts right up and mostly runs fine but we have a new issue. If you go sideways on a slant, it will shut off. You can stand on it, shake it back and fourth and it will also shut off at idle. Its seems to idle fine and for the most part idle fine. If you hold the throttle down, it does not shut off. Only when idle and on a slant or shaking back and fourth.
I took the carb back off and double checked the float level thinking this is what it was and it was correct. I cleaned everything up again and reassembled with the same issue.
I took it apart again and adjusted the float up a little thinking maybe it was just a touch low and still have the same issue.
Anybody have any ideas to what may be causing this?
