02 f350 7.3 cclb
Trying to figure out my ac right now it's 102° out side right now and the truck is blowing around 65° while parked and 55° when moving still roughly 80° in the cab .
gauge reads 50 psi on the low side and ac clutch is constantly engaged .
Update it's about 85 degrees now low side is 44psi and high is 215psi truck is blowing 60°
Ac clutch stays on and won't disengage unless I pull the low pressure switch
Blend door moves when I switch settings temp changes when I adjust temp so thinking the blend door and actuator work finally have condensation dripping after I cleaned the evap coil and condenser as well
