Recently did a full 100,000 mile service on this truck, which included replacing the upper O2 sensors. There was a CEL...buddy said he had the truck diagnosed and these were faulty.
After replacing the upper sensors, the code went away for a good while (over a week and 1,000+ miles). This morning, the CEL came back on, so I went over to his place with my laptop and ScanXL software. Turned out to be a P0430, which points to bank 2:
Quote:
Catalyst System Efficiency Below Threshold (Bank 2)
Where is cylinder number 1 located (to help locate bank 2)?
It's the 5.3L Vortec. Thanks!
I'm going to check the system for any leaks, but I'm thinking this could possibly be the catalytic converter (O2 sensors already replaced), as the engine was run on 20W-50 SJ-rated oil until I changed it to Motorcraft Syn Blend...although it does not burn any oil.
