quote:
Originally posted by JohnBrowning:
Patman, How can 40%-60% greater material loss's not affect long term life cycle. GM is not useing an additional 40%-60% more material to offset this so "more wear = more wear"! I think reason and common sense rules out the idea that "More Wear=Less Wear"!
Patman, TS was not useing the differences in wear rates between GM and Toyota engines to compare oils. THis would not be good. It is quite acceptable to compare one engine against another of simalar displacement and number of cylinders. It also helps to keep "V", "W", "I" or "B" configurations like as well. How the valve are acuated has no bearing in how the bearings,pistons or rings are wearing!
My point is that the two engines might use similar metallurgy, but you can bet it's not totally identical. For one, I believe the Toyotas are all aluminum, while the GMs use iron blocks. That is a significant difference.
I'm simply saying that there are plenty of high mileage GM trucks on the road, there is no evidence in real life which suggests that GM trucks engines die at an early age.
I agree that you want to see the lowest wear numbers you can in UOA, but some engines just will not show you these kind of numbers, it's their nature, but for them it doesn't mean they'll die earlier than another engine. Just look at the 4.0 Jeep engine, it shows high iron in a lot of UOAs, yet is a very long lasting engine. I'd love to see UOAs on some of the most durable engines ever built, such as the slant six or the Ford 4.9 straight six. It wouldn't surprise me to see they show wear metals higher than we'd feel comfortable with.
Another engine which doesn't show super low wear numbers is the LT1 engine I have in my Firebird, but yet I know many guys out there who have driven the hell out of these cars and still have gotten very long life out of them.
Spector often says it best, watch the trends in UOA, but don't be concerned if the numbers are always higher, because it doesn't always mean that particular engine is going to die any sooner.
By the way, I've yet to hear of a Toyota going one million miles on it's original motor, like that Chevy truck did.
