The vehicle is a '01 Ranger XLT 2WD with coil springs.
Removing the front lower ball joint was pretty easy with the loaner tool from AutoZone, OEM p/n 27023. The adapters & receiving tubes worked well.
However, the installation hasn't worked out as well. The ball joint press kit 27023 has the receiver tubes of the right size to fit on the top & bottom of the ball joint, but the c-clamp frame press isn't "tall" enough to go over both receiving tubes & both adapters. I've also picked up the adapter kit, OEM p/n 27166, but that didn't have short enough receiving tubes to fix the problem. It was labeled for Ford 2WD vans.
I'm going back to pick up another adapter set, OEM p/n 27163, but I'm not sure if that will work or not since it's labeled for 1996-2004 Ford Taurus & Mercury Sable.
OEM Loaner Tools
What are my other options here? I'm willing to buy if loaner tools don't cover this application.
Thanks.
OEM Loaner Tools
Thanks.
