OVERKILL
$100 Site Donor 2021
Originally Posted By: 01rangerxl
In hind-sight I am wondering if the difference is that I lack 2HI on the Expedition. It only has "Auto/4HI/4LO", which may explain the absence of the vacuum setup in this vehicle, and likely explains why you probably DO have it if you have a "2HI" selector option.
http://en.wikipedia.org/wiki/Control_Trac
Quote:
Auto mode...
This is how Control Trac worked for '97 and on. My Explorer had a version of Control Trac that was unique to '95-'96. It has 2Hi/4Auto/4Lo. It had the vacuum disconnect. It was Control Trac you could turn off, but your only choices are 4WD when the truck decides or full on mud hole mode.
Yes, I had a '97, but I remember test driving a '96 that had the 4-position switch. Our first Expedition, a '98, also had the 4-position switch, but our other two have only had the 3-position ones.
Quote:
Auto mode...
