I had used KYB quick struts and shocks on the 2011 Silverado I had before the Colorado. They rode much better than the worn out OEM I had removed.
I apologize to everyone.. I have to edit my post..I'm glad you were able to get the Toyota stuff.. I did that with my Scion tC, and if they lasted 13 years then I'll get another 13 out the new ones! Oh and no noise or binding at the top mounts either!I did follow the service manual that says to ONLY tighten the center nut (strut rod nut) when the car is on the ground with the weight on the tires.EDITED BELOW
Absolutely agree with youthe sachs-damped Volvos have been my favorite “feel” for most of the driving I do.
kyb hasn’t been getting a good rap.
bilstein has become the name for digressive valving, but frankly it’s not my favorite method. The B6 at least in the 4Runner tuning isn’t overly “sticky” but in the 5100 the difference between the sticky spot and the “wide open” (“oh we are moving now”) valving was a detriment on mine as they aged.
a standard, progressive shock would be a great fit for the Camry; bilstein b6 is a decent bet if you want a little cornering and quality. Idk who builds decent units that provide standard tuning with quality lifespan outside of oem nowadays. At least with Toyota, oem should be good quality, better than Monroe. (I do like some Monroe products but every new buy seems a roll of the dice with them).
You are going to be so surprised when you discover OE Toyota strut and springs are:I think I’ll be more than happy with new OEM Toyota struts and springs
(I think you guessed it) - KYB.
Like a few others have already mentioned, off the shelf KYB’s are valved differently than OEM provided KYB.
KYB = Keep Your Bilsteins
hey I think I replied to your other post about this.. glad you got the toyota parts installed! and that they're working out for ya..If they made Billy’s for my application I would’ve definitely gone that route. My new OEM Toyota struts were: Sachs for the front and KYB for the rear (Toyota specific valving).
thanks for the update!! I think I remember something about the steering shaft inside the car needing grease and it was Toyota. That it was the bearing or carrier in the steering column shaft and once they added some bearing grease it was quiet again. Not saying that's it, but help ya search for that in your repair quest.Thanks buddy! I’m still not done as I’m on a quest to find the random ever so slight knocking when I turn my steering wheel at low speeds or when stationary. I double checked everything and the struts are good. I think when the PO owned the car and drove on the blown struts for God knows how long, it caused other suspension components to wear out rapidly. Next will be ball joints, sway bar bushings, and sway bar end links as the new Beck Arnley links I installed have torn boots not even a month later..
wow didn't know that the beck arnley links were that bad! sheesh.. and here I was thinking of using them on my scion tC in the rear! ouch..
oh heck ya.. thanks for that, was able to download it, very cool how it's setup compared to the one I have.Thank you also for the heads up! I appreciate members like you that are always sharing valuable info. How’s that’s repair site working out for you? Any good?
Yep. Had my awesome Indy shop install my KYB’s. Rides as good as new , and have been on 2 years and still working perfectly fine. No leaks, nothing. Would buy another set in futureAre these are the struts where you decided not to follow the mounting instructions, and threw away the factory hardware and used an impact gun- both specifically forbidden in the KYB instructions?
That’s what you described previously:
https://bobistheoilguy.com/forums/threads/new-kyb-strut-plus-popping-noise-on-turns.376088/
After years modding at TN, we’ve observed quick strut failures almost always come down to installation errors. This seems another case of that.
