Just like the title says.
I'm wondering this as I've had the truck since new (158K now) and it has always had a fiberglass shell on.
The rubber pieces in between some of the leaves are getting in bad shape and there is a "clank" that happens when changing direction. The clank has been sort of "fixed" with some lube, but that will be temporary as it wears away.
FYI, the drive shaft has been rebuilt as well as the rear end...no problems there.
So...fire away!
So...fire away!
