1991 VW Jetta Turbo
Total miles 19,477 (since rebuild)
Miles on oil 6,230
AMSOIL 15w-40
Oil filter Mahle OC51
Air filter Mahle Paper
Sample date 11/01/06
Oil was in vehicle for 5 months. 2Qt makeup
First run with AMSOIL, before this was Rotella
Mix of highway and city miles put on vehicle
Aluminum..........6
Chromium..........4
Iron.................99
Copper..............6
Lead.................3
Tin....................1
Molybdenum.......5
Nickel................1
Manganese.........1
Silver................0
Potassium..........0
Boron...............18
Silicon..............4
Sodium.............3
Calcium.........3717
Magnesium.......29
Phosphorus......1028
Zinc................1166
Barium.............0
Viscosity………….81.3
Flashpoint F…….440
Fuel%..............0.5
Coolant%………..0.0
Water%……………..0.0
Insolubles%......0.4
TBN/TAN…………..9.9
I had the engine completely rebuilt three years ago this coming spring. I have an oil pressure problem, that being I have no oil pressure at operating temp. I get 20psi at cold start up but when the oil warms up it drops to zero and stays there. The gage is good as everything in the engine is new. That oil pressure reading is at the head. I have oil volume just no pressure. If you take my cam cover off you will get soaked by the oil that flows up there around the cam and lifters. Engine smokes on startup. The shop that did the head messed up on it obviously for the smoke I'm getting. I go through a qt of oil every 3k miles. Running a stock Mahle OC51 oil filter and a stock Mahle paper air. The injection pump has been rebuilt and tweeked so I'm getting plenty of fuel. If I run up the RPM's with about 15PSI of boost I can get a nice black cloud of smoke. Needless to say nobody tail gates me.
I get lifter tap, some days bad and some days not at all. I figure it is from the oil pressure issue. I just turned 20k total miles on the engine since I had it rebuilt. It was broke in on Rotella SAE 30 for the first 500 miles and then 3k after that and then 15w-40 rotella at 3k miles up until I put the AME in. I always run a Mahle OC51 oil filter. I had the K14 turbo rebuilt when I did the engine and I installed a 2.5" down pipe off the turbo and it runs 2.5" all the way back to a flowmaster muffler. My best fuel mileage has been 52.7mpg. On average I get 46-49. This sample I have ran about 14 gallons of waste veggy oil mixed in with the diesel at a 50/50 mix. It sure seemed to like that, ran smoother than on regular diesel and smoked less. That is about all I can think of for now. Again, comments welcome.
Miles on oil 6,230
AMSOIL 15w-40
Aluminum..........6
Chromium..........4
Molybdenum.......5
Manganese.........1
Magnesium.......29
Viscosity………….81.3
Flashpoint F…….440
Coolant%………..0.0
Water%……………..0.0
TBN/TAN…………..9.9
