Babelfish translation is sometimes ridiculous, but will be enough to understand the test procedure and results together with my small corrections. Hope you will find it interesting.
GOST = Russian National Standard
g/sme = g/cm3
S = deg C
tyuey g/m2.sut = g/m2 per 24 hours
Copper My = Copper M1
Brass Of 1'e = Brass L63
Cast Iron ARE MF 22-44 = Cast Iron (grey) 22-44
Foam, sme = Foam, cm3
PH value (rN) = PH
http://www.autoreview.ru/test_acs/antifriz_219/antifrz1.htm
http://www.autoreview.ru/test_acs/antifriz_219/antifrz2.htm
http://babelfish.altavista.com/babelfish/tr
g/sme = g/cm3
S = deg C
PH value (rN) = PH
