Well it's not dumb - but just treating it like a collector's antique car. I know guys with cars and with nothing better to do, would flush all the fluids.
And when you figure you are going to spend $40 on gas, why not change the oil. If Jiffy lube charges you $25, go ahead and put in some great oil recommended by others here on BITOG.
So no, not dumb. I know I changed my motorcycle oil at the beginning of this season. Based on recommendation here on the forum I picked Delvac 1300 and loved the way the bike ran afterward. Now it's back to shifting reluctantly after 800 miles in service. So I'm going to change it again, and use Delvac again. I think it's cleaning out the other junk. And I'll change it again (at $5.88, cheap) if I need to. I figure after 3 or 4 tries it should be ok. If not, I'll try Shell Rotella! Good luck with you plan.
