229.51
by RogerBacon
28 minutes 41 seconds ago
One way to get the rust off under your vehicle...
by rollinpete
Today at 04:04 AM
Loud hum noise from front brakes
by Jimmy9190
Yesterday at 10:47 PM
Rat: Trap or Poison
by WhyMe
Yesterday at 10:27 PM
STIHL Hp ultra fail??? Or my fault???
by Matt2stroke
Yesterday at 09:42 PM
Wrestling pretzel hold. Ouch!
by callbay
Yesterday at 09:41 PM
Serpentine Belt noise
by Tdbo
Yesterday at 09:31 PM
Coolant Leak
by Ducked
Yesterday at 09:13 PM
Does lots of starts let gas get in oil?
by tc1446
Yesterday at 08:44 PM
Avalanche front and rear diff change.
by spasm3
Yesterday at 08:40 PM
Abuse proof rental home flooring
by Oldtom
Yesterday at 08:17 PM
Low Noise Oil
by Ducked
Yesterday at 07:55 PM
2017 Dodge charger review
by gabriel9766
Yesterday at 07:51 PM
Dry reusable air filters?
by WillB
Yesterday at 07:42 PM
Batteries @ Menards
by Tdbo
Yesterday at 07:29 PM
Blotter Spot Test
by Emanuel
Yesterday at 07:22 PM
Is arming teachers the answer?
by ZZman
Yesterday at 06:45 PM
Another ATF question... I aplogize
by bardos
Yesterday at 06:12 PM
To Seafoam or Not?
by Marco620
Yesterday at 06:07 PM
2017 Ford ecoBoost 1.5 Oil Filter Top View
by tenderloin
Yesterday at 05:50 PM
WiseOne, ryan6548, pjmbull, 92zx, Ara
64253 Registered Users
61 registered (4WD, aquariuscsm, Armkb, 2015_PSD, alarmguy, 5 invisible), 1073 Guests and 101 Spiders online.
64253 Members
65 Forums
278522 Topics
Page 2 of 3 < 1 2 3 >
#597269 - 11/28/04 08:33 AM Re: Good Oil for Locks ?
DNaatz Offline
Loc: Rochester, MN
So lotsa different advice(s) here.
My specific question relates on what's good for an ignition key that occasionally jams but always eventually starts the car.
I suggest WD40 which I have used in outside door locks and should not harm any electrical wiring it might get into - vs comments on graphite in earlier posts not being good for electrical contacts.
Any other thoughts for lubing the ignition switch tumblers?
#597270 - 11/28/04 12:20 AM Re: Good Oil for Locks ?
wileyE Offline
Loc: Kitsap, WA
Could be your key is just getting worn out? teeth are getting rounded off etc. I found this true a few times on cars and just needed to make a new key off the original (after tearing the house apart trying to find it, LOL)
#597271 - 11/28/04 06:52 AM Re: Good Oil for Locks ?
DNaatz Offline
Loc: Rochester, MN
Both keys act up, one is a new key.
So methinks its tumblers sticking or the ignition assembly wearing out (40,000 mi seems too early for that).
On another forum a gentleman said never used WD40, use graphite spray. I may just check with a locksmith for their advice, hopefully they won't give me something to mess it up so they can make more money!
#597272 - 12/07/04 05:02 AM Re: Good Oil for Locks ?
seotaji Offline
Loc: USA
i had a dodge that had a defective ignition switch from the factory.
i wouldn't doubt that yours was defective either.
just replace it or rebuild it (so you don't have to walk around with two sets of keys ala chevy caprice.
also, i've never had to use anything in my (car/house/otherwise) locks and they've been working fine for decades.
[ December 07, 2004, 09:31 PM: Message edited by: seotaji ]
#597273 - 12/07/04 09:05 PM Re: Good Oil for Locks ?
luvs2drive Offline
Loc: Durham Region, Ontario, Canada
A quick shot of T-40 Krown rustproofing always works for me. My buddies VW doorlock use to suffer from freezing and was hard to turn. Now it works fine.
#597274 - 12/08/04 04:52 AM Re: Good Oil for Locks ?
Tones Offline
Loc: Houston, TX
This is a funny topic because there are a lot of strong opinions on this. Some say use nothing but powdered graphite, others use grease.
I have had excellent results using Remoil. It is a light gun cleaning oil spray with suspended teflon. The oil is not like WD-40, it will not evaporate. I have used it in sensitive electronics with great success. The excess oil will seep out, but it leaves a thin film of oil and the teflon behind. This stuff is very slick and keeps things lubricated for a long time. I use it on all kinds of hinges and locks. I think wallyworld carries it. I haven't had to buy any in a while (years) because a little goes a long way.
#597275 - 12/08/04 05:52 AM Re: Good Oil for Locks ?
Pablo Offline
Loc: Duvall WA - Pacific NW USA
I don't like the left behind WD-40.
I second the contact cleaner and PB Blaster clean-up followed by a very light silicone lube on the key.
#597276 - 12/16/04 05:06 AM Re: Good Oil for Locks ?
ChrisW Offline
Loc: Central Valley, CA
I use to use graphite...hmm maybe not anymroe after reading this.
Perhaps GC would be ideal? It works great for cars! [Big Grin]
#597277 - 12/27/04 10:36 PM Re: Good Oil for Locks ?
Kestas Online   content
Loc: The Motor City
quote:
Originally posted by Tones:
...I have had excellent results using Remoil. It is a light gun cleaning oil spray with suspended teflon. The oil is not like WD-40, it will not evaporate. I have used it in sensitive electronics with great success. The excess oil will seep out, but it leaves a thin film of oil and the teflon behind. This stuff is very slick and keeps things lubricated for a long time...
Perhaps I can finally put my old bottle of Slick 50 to good use!
#597278 - 12/30/04 05:42 PM Re: Good Oil for Locks ?
moribundman Offline
quote:
I've heard the graphite lube isn't good for modern cars. Nowadays the locks have electrical contacts that can go buggy on you if you use the graphite lube. That's why some don't recommend it for automotive locks. I'll have to check out the triflow stuff.
I suppose it depends on the lock and where it has electric contacts?
quote:
Local locksmith shop recommended triflow, said to stay away from graphite since it gums up the lock. I had a house lock rebuilt that was worn out. It was full of chunks of graphite.
Graphite is not ideal in a moist climate, because then it actually does attract dirt. It seem to work well in dry climate. Also, not very much powdered graphite is necessary to lube the lock properly. You wouldn't want to get they key greasy each time you lock or unlock you car.
#597279 - 12/31/04 08:16 AM Re: Good Oil for Locks ?
labman Offline
Loc: Nothern USA
quote:
One more disadvantage of gadgets more bother than they are worth. I haste the power windows I got stuck with on my Cavalier. Dumb, dumb, dumb.
#597280 - 01/01/05 04:35 AM Re: Good Oil for Locks ?
pitzel Offline
Loc: Saskatchewan, Canada
My car owner's manual says 5W-30 Synthetic motor oil for lock lubrication.
#597281 - 01/01/05 07:28 PM Re: Good Oil for Locks ?
msparks Offline
Loc: Clarksville, Tennessee
Amsoil sells a synthetic spray grease. I've used it on locks before. I've also used the Amsoil Metal Protector but I don't think the film will last as long a grease based product.
#597282 - 01/01/05 07:51 PM Re: Good Oil for Locks ?
Loc: The Motor City
quote:
Originally posted by MONKEYMAN:
...I had a house lock rebuilt that was worn out. It was full of chunks of graphite...
I believe graphite lube is simply graphite with a solvent carrier that dries off. A little bit of graphite is good. I suppose if you lube it too often you'll accumulate a lot of dried powder.
#597283 - 01/02/05 11:15 PM Re: Good Oil for Locks ?
edvanp Offline
Loc: Michigan
I've had good luck with MMO [Cool]
