Advice on spark plugs for 90,000 mile Accord
Originally Posted by tig1
The plugs are fine. I changed mine at 125K and put NGKs in. However you are needlessly changing oil too soon. I would double that to 10K as you are using M1 0-20EP. Notice my 2007 Ford Fusion at the bottom.
I change it at 5,000 OCI because of all the horror stories I have read about going by the MM. This engine is very hard on oil.
Originally Posted by nthach
NGK or Denso OEM type is the way to go for these. Follow Honda's maintenance minder.
A VCMuzzler is the best thing you can do for a Honda V6, the VCM system on these is known for issues.
I've had a VCM muzzler installed since about 60,000 miles when I found out about them. It is awesome!
