Whatever the interval from the manufacturer is I go by 1/2 that and just drain the radiator and refill, that way by the time it gets to the mileage where the coolant would be totally spent system wide, all the coolant in the system has been changed because the radiator holds approximately 1/2 the systems coolant more or less and you are draining and refilling it twice as often.
This way you always have really fresh coolant in the system and lots of active additives for maximum efficacy. My Santa Fe which had a timing belt drove on its original water pump and radiator when the camshaft let go at 535,000km (300K miles) The water pump is supposed to be changed with the belt but I never did it.
