Extended Oil Drains
by The Critic. 11/20/18 12:08 AM
Extreme not maintained
by tiger862. 11/19/18 10:52 PM
Remember when the year 2000 was the future?
by PeterPolyol. 11/19/18 09:38 PM
Supertech Syn in new tgdi?
by BTLew81. 11/19/18 09:06 PM
New Hemi 5.7 - Oil Suggestions?
by Greg L. 11/19/18 08:53 PM
Fluid Change on Chrysler 9 speed (ZF) trans
by 92saturnsl2. 11/19/18 08:41 PM
New tire size, new tire pressure?
by Melectric. 11/19/18 08:40 PM
Pep Boys Black Fri M1 $19.98 5 qts
by tenderloin. 11/19/18 08:10 PM
Supertech, first time
by buck91. 11/19/18 08:07 PM
Throttle frozen after sitting a few months
by atikovi. 11/19/18 08:07 PM
How much $ to have your own brand?
by Red91. 11/19/18 07:43 PM
Used blizzaks
by Ndx. 11/19/18 06:47 PM
Federated PG111F Cut Open Jeep 2.5
by troutfisher. 11/19/18 06:06 PM
2013 Ram front fender rust
by irv. 11/19/18 05:50 PM
Pro Motive PH 241 CUT OPEN
by 53' Stude. 11/19/18 05:27 PM
Mobil 1 FS Differential fluid
by bobbyjoe. 11/19/18 05:20 PM
Car randomly switches off
by Spetz. 11/19/18 05:16 PM
379exhd, Drew3419, KevinGC, Jaygee, bryanmacb
66478 Registered Users
34 registered members (bbhero, 2015Corolla, ArrestMeRedZ, bamorris2, 4 invisible), 887 guests, and 25 spiders.
Topics293,810
Posts4,904,908
Members66,478
Most Online2,553
Oct 27th, 2018
Yamaha snowmobile OEM oil filter mystery goo #4897951
10/16/18 01:37 PM
10/16/18 01:37 PM
Colorado
sw99 Offline OP
sw99  Offline OP
Colorado
I have never seen this before. It's similar to the consistency of Vaseline. Is this an engine break in grease or what? This is from the break in period on a Yamaha 998 triple engine. Oil looked as it should from break in. 122 miles & 12.2 hours on the machine.
[Linked Image]
[Linked Image]
2016 Nissan Versa S 1.6L
2018 Subaru Outback 2.5i
2018 Ford F350 6.2L
Re: Yamaha snowmobile OEM oil filter mystery goo [Re: sw99] #4898043
10/16/18 03:00 PM
10/16/18 03:00 PM
Alberta
carviewsonic Offline
Alberta
Some type of assembly lube would be my guess...
'18 Impala
'05 Park Avenue
'07 Honda Accord
'09 VStar 1300
Re: Yamaha snowmobile OEM oil filter mystery goo [Re: sw99] #4898095
10/16/18 04:54 PM
10/16/18 04:54 PM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
I accidentally plugged a filter with assembly lube when I was younger... so I do know that it is a possibility.
Re: Yamaha snowmobile OEM oil filter mystery goo [Re: sw99] #4898137
10/16/18 05:52 PM
10/16/18 05:52 PM
Tennessee
goodtimes Offline
goodtimes  Offline
Tennessee
Only found on the clean side of the filter? I imagine they want to protect the engine very well as it may be in storage for some time before sale. They should know if contacted. From the factory should be no problem, they know what's best.
Re: Yamaha snowmobile OEM oil filter mystery goo [Re: sw99] #4898240
10/16/18 08:00 PM
10/16/18 08:00 PM
Oshawa, Ont. Canada
irv Offline
irv  Offline
Oshawa, Ont. Canada
I assume this is a brand new sled and this is its first oil change? I'd document, take pics, notes, etc, talk to your dealer and send these pics to Yamaha in case of future problems.
Not that this likely has anything to do with it, but I personally dislike Yamalube and Yamaha filters. Not many good news stories, VOAs and UOAs with Yamalube products. The price they charge for them is astronomical as well. Both products prices could be cut in half and you'd still be paying too much for them based on what you receive.
I purchased my Vector used so I have never seen that before, but then again, I have never done a C&P with any of the filters. Dd the oil come out sludgy/thick or was it normal?
Edit: Are you a member at TY4stroke.com? https://ty4stroke.com/ - https://ty4stroke.com/forums/ If not, I'd join and ask there. It's a great site full of everything, and then some.
2017 Chevy Impala 3.6 L.
2013 Ram 5.7 L Hemi Bighorn QC 4x4
2008 Chevy Malibu 2.4 L Ecotec
Pennzoil Platinum and/or Pennzoil Ultra Platinum in all 3.
Re: Yamaha snowmobile OEM oil filter mystery goo [Re: sw99] #4898700
10/17/18 12:20 PM
10/17/18 12:20 PM
Colorado
sw99 Offline OP
sw99  Offline OP
Colorado
Yes, only on the outside pleats that I can see. Yes this was the factory installed filter.
This is actually on a Textron / Arctic Cat side by side that uses a Yamaha 998 sled triple. Yamaha has been working with AC for years and this was a big reason I went with this machine. I replace with a Fram PH6017A since it's a little longer and has a pretty good reputation. I also have some HiFlow 204's to use also.
2018 Ford F350 6.2L
Re: Yamaha snowmobile OEM oil filter mystery goo [Re: sw99] #4903288
10/22/18 05:20 PM
10/22/18 05:20 PM
Oshawa, Ont. Canada
irv Offline
irv  Offline
Oshawa, Ont. Canada
I use a HF147 on my Vector, they are good filters.
You never did say if the oil came out sludgy or not? I would assume, based on the looks of that filter, that it at least had a few lumps in it? shrug
Re: Yamaha snowmobile OEM oil filter mystery goo [Re: sw99] #4903874
10/23/18 09:55 AM
10/23/18 09:55 AM
Colorado
sw99 Offline OP
sw99  Offline OP
Colorado
Oil had no clumps at all, looks fine.
2018 Ford F350 6.2L
