Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
Bought a used Ford Fusion
by krismoriah72. 12/17/18 04:14 PM
Valvoline NextGen Tech Oil
by DirtyOilGuy. 12/17/18 04:08 PM
Witty comment regarding a lame car
by Number_35. 12/17/18 03:43 PM
'80s oil literature
by Number_35. 12/17/18 03:26 PM
Recommend on oil for 2017 Kia Sportage 2.4
by SlavaB. 12/17/18 02:57 PM
No more Delo at my Costco. T4 now
by BeerCan. 12/17/18 02:16 PM
Found this
by davedude. 12/17/18 02:15 PM
hopsofir, genera2800, oghl, hdlss, dsmdylan
66711 Registered Users
32 registered members (Char Baby, aleneros, CB900F2, Bjornviken, bluesubie, Brandon9797, 4 invisible), 901 guests, and 46 spiders.
Topics295,207
Posts4,929,895
Members66,711
Most Online2,553
Oct 27th, 2018
electrical issue, 98 K1500 #4894540
10/12/18 08:29 AM
10/12/18 08:29 AM
southwest Mo.
wtd Offline OP
wtd  Offline OP
southwest Mo.
Last night while driving this truck, I noticed that the lights in the middle of my instrument panel seemed to be out since the lighting was dimmer in that area. My high beam indicator was also not working. A little while later, it appeared that the lights had come back on as the entire instrument panel lighting was the same but my high beam indicator was still out.
When I was almost home, I used my high beams and the indicator lit up like normal. I did check the battery cables when I got home and they were pretty tight but I was able to snug them a little. This morning I tested the lights again and the instrument panel lights all seem to be working but the high beam indicator is out again.
Does anyone have any other ideas on where I should look to correct this problem? Thanks.
Wayne
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
Re: electrical issue, 98 K1500 [Re: wtd] #4894543
10/12/18 08:36 AM
10/12/18 08:36 AM
Idaho
CT8 Offline
CT8  Offline
Idaho
Check the grounds.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: electrical issue, 98 K1500 [Re: wtd] #4894554
10/12/18 08:47 AM
10/12/18 08:47 AM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
Does the dimmer for the dash lights have any effect on it?
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: electrical issue, 98 K1500 [Re: wtd] #4894569
10/12/18 09:01 AM
10/12/18 09:01 AM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
Check the alternator and cables to the alternator?
  • 2017 Toyota Sienna
Re: electrical issue, 98 K1500 [Re: wtd] #4894574
10/12/18 09:04 AM
10/12/18 09:04 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
The odometer on my cousin's 2005 Buick Lacrosse was not working . We watched several you tube videos on this . Found videos , also , showing how to take the dash apart .
There are people that repair these instrument clusters by replacing the individual little lamps .
My cousin bought an instrument cluster at a local " Wrench A Part " for around $ 35 . He just lives with the odometer being incorrect .
You couls buy a used one and send in the original to be repaired .
Wyr
God bless
Re: electrical issue, 98 K1500 [Re: CT8] #4894650
10/12/18 10:48 AM
10/12/18 10:48 AM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
Originally Posted by CT8
Check the grounds.
When the grounds were bad on my Dad's 97 K1500 the dash would flash with the blinkers.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: electrical issue, 98 K1500 [Re: JTK] #4894726
10/12/18 12:23 PM
10/12/18 12:23 PM
southwest Mo.
wtd Offline OP
wtd  Offline OP
southwest Mo.
No, I messed around with that and it doesn't change anything. I know that the dimmer switch is a weak spot on these trucks.
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
Re: electrical issue, 98 K1500 [Re: wtd] #4894749
10/12/18 12:52 PM
10/12/18 12:52 PM
southwest Mo.
wtd Offline OP
wtd  Offline OP
southwest Mo.
The alternator is charging fine and the wires to it are tight. The only grounds I can see are the body ground from the firewall to the frame and from the frame to the back of the engine. I sprayed them down with some spray cleaner and rust remover to see if that helps. If not, I will take the loose at the frame and clean everything when it quits raining.
Thanks for the replies.
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
Re: electrical issue, 98 K1500 [Re: wtd] #4894772
10/12/18 01:09 PM
10/12/18 01:09 PM
USA
mk378 Offline
mk378  Offline
USA
It would be a small ground wire behind the dash that does this. Also the plugs on the cluster could be making poor contact.
Overall the major parts of the electrical system seem OK since the headlights themselves always light up, on both beam settings.
Re: electrical issue, 98 K1500 [Re: wtd] #4894779
10/12/18 01:13 PM
10/12/18 01:13 PM
VW Fanboy Island
VW Fanboy Island
Your cables might be corroded internally, if it has original ground cables you should inspect them closely or probably just replace them. My Dad's truck needed new cables just last year and I'm pretty sure they were the originals.
Re: electrical issue, 98 K1500 [Re: mk378] #4894857
10/12/18 02:56 PM
10/12/18 02:56 PM
southwest Mo.
wtd Offline OP
wtd  Offline OP
southwest Mo.
I will look for this ground and see what it looks like.
maxdustington, the ground straps in the engine compartment are not original. I upgraded them some years ago to the bigger heavier duty straps that were recommended at the time. They are braided straps and are not corroded.
There are several interior lights that have quit working over the years. The light on the cargo light switch no longer lights up and two of the lights on the radio pre-set buttons went out recently.
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
