Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
Bought a used Ford Fusion
by krismoriah72. 12/17/18 04:14 PM
Valvoline NextGen Tech Oil
by DirtyOilGuy. 12/17/18 04:08 PM
Witty comment regarding a lame car
by Number_35. 12/17/18 03:43 PM
'80s oil literature
by Number_35. 12/17/18 03:26 PM
Recommend on oil for 2017 Kia Sportage 2.4
by SlavaB. 12/17/18 02:57 PM
No more Delo at my Costco. T4 now
by BeerCan. 12/17/18 02:16 PM
Found this
by davedude. 12/17/18 02:15 PM
Practice CLS material
by RDY4WAR. 12/17/18 01:52 PM
2005 Chevy Silverado 5.3 vortex
by MSpeer. 12/17/18 12:01 PM
hopsofir, genera2800, oghl, hdlss, dsmdylan
66711 Registered Users
28 registered members (citationxeleven, Char Baby, bluesubie, Brandon9797, 53' Stude, ARB1977, 1 invisible), 822 guests, and 31 spiders.
Topics295,205
Posts4,929,884
Members66,711
Most Online2,553
Oct 27th, 2018
ENEOS 75w90 GL5 anyone using it in Differentials #4894531
10/12/18 08:18 AM
10/12/18 08:18 AM
new jersey
jrvn Offline OP
jrvn  Offline OP
new jersey
http://www.eneos.us/products/eneos-gear-oil/ im thinking of using this gear oil in my 2013 Tacomas Differentials has anyone used it in the differential axles or have any knowledge or input whether it would or wouldn't be a good choice, it seems that its a very thin oil based on its Typical properties, viscosity at 40c is 78.8 and 100c is 14.5 but the VI is 193, seems very thin for differential use although Toyota recommends a thin 75w85 gl5 for the diffs. Also im pretty sure this gear oil is Semi synthetic too and seems to be used with great success in manual transmissions even with its GL5 rating, other than that I cannot find too much info on it, my concern being that its already a thin oil and it would shear down into an even thinner oil and be not even as good or better than a 75w85 that's rec'd.
Re: ENEOS 75w90 GL5 anyone using it in Differentials [Re: jrvn] #4894624
10/12/18 10:10 AM
10/12/18 10:10 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Maybe read this recent thread and apply. If ST 75w-90 works then I bet ENEOS 75W-90 will work.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4891845/1
2014 Nissan Rogue S CVT, OC#10 47272mi-QSUD10W30+5w20 Toughguard Filter; '17 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
Re: ENEOS 75w90 GL5 anyone using it in Differentials [Re: jrvn] #4894634
10/12/18 10:26 AM
10/12/18 10:26 AM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
I am not sure what you mean by thin as it falls into the acceptable viscosity range of a 75W90.
I prefer a 75W110 as it is a good midrange viscosity for all temperature extremes, For example, Amsoil has a 75W110 blend such as:
75W110 PDS
Scars remind us of where we have been, but do not have to dictate where we are going.
Re: ENEOS 75w90 GL5 anyone using it in Differentials [Re: jrvn] #4894691
10/12/18 11:42 AM
10/12/18 11:42 AM
MN
oil_film_movies Offline
MN
I've always thought Amsoil makes the best differential oil. The evidence is old though.
Anybody know if there is a benefit to lots of moly or teflon in GL-5 diff oil?
It would be nice to identify the lowest friction, and best wearing diff oil. Until there is some more proof, its hard to beat Amsoil Severe Gear.
Re: ENEOS 75w90 GL5 anyone using it in Differentials [Re: jrvn] #4894699
10/12/18 11:56 AM
10/12/18 11:56 AM
Midwest USA
LoneRanger Offline
LoneRanger  Offline
Midwest USA
I have it in the front and rear differentials of the my Subaru Forester. I need to change it out, last change was @ 33,000 miles and I'm at 65,000 now. Subaru recommends changing diff oil every 30,000. The Subaru layout has the front diff inside the transmission, in my car that's the 5-speed manual so the front differential shares the ENEOS 75W90 with the manual transmission. The rear differential is not limited slip, Subaru used to put LSD's in the rear up through 2007 I think, then they went to the fake LSD thing all the manufacturers cheap out on now where they use an open diff and electronic traction control to apply single wheel braking to whichever one is losing traction. I'd rather have a bonafide LSD back there but oh well.
'09 Subaru Forester ...................(QS HM 5W30)
'16 Moto Guzzi Stelvio 1200 .....(ENI i-Ride PG 10W60)
Re: ENEOS 75w90 GL5 anyone using it in Differentials [Re: MolaKule] #4894792
10/12/18 01:34 PM
10/12/18 01:34 PM
new jersey
jrvn Offline OP
jrvn  Offline OP
new jersey
i think im basing it on the 40 degree and 100 degree celcius info given from ENEOS, most other noted 75w90 gl5 gear oils are slightly thicker with a lower VI index at these temps, and im not sure since I cannot find a UOA for the ENEOS stuff that it may shear down more to a point where it may effect the wear of the rear diff, actually the viscosity specs and VI are very close to MOTUL gear300 which I think is a superior gear oil. im a little on the fence using the ENEOS since I really cant find out any in depth reviews or analysis on it, I usually do the differentials and transfer case every 30k miles on the truck. [Linked Image] at the moment im using REDLINE 75w85 gl5 which hasn't really gotten rave reviews here on BITOG for being too thin and having mucky drain plugs due to wear. im thinking of going to a 75w90 and this ENEOS is slightly thicker at 40 and 100 degree C with a higher VI than the REDLINE 75w85 stuff, and at the same time being thinner at those temps than most over the counter fluids other than MOTUL gear300 and its price online is better than MOBIL1, REDLINE, AMSOIL and all the other usual suspects.
Re: ENEOS 75w90 GL5 anyone using it in Differentials [Re: LoneRanger] #4894795
10/12/18 01:37 PM
10/12/18 01:37 PM
new jersey
jrvn Offline OP
jrvn  Offline OP
new jersey
have u ever done a UOA or know of anyone UOAing it im interested to know how it held up doing 30k miles
Re: ENEOS 75w90 GL5 anyone using it in Differentials [Re: jrvn] #4896434
10/14/18 04:19 PM
10/14/18 04:19 PM
Midwest USA
LoneRanger Offline
LoneRanger  Offline
Midwest USA
Nope, sorry.
