My suggestion is to use a quality oil of your choice and mix it at 32 to 1.
Those who claim certain oils are diluted are probably not as correct as they think they are. Amsoil makes fine products, however the claim that you can mix the oil at 100 to 1 because the oil is not diluted just does not make mathematical sense. Using Amsoil's logic, certain other brands of oil would have to be 50% diluted with a solvent as thin as gasoline.
Many 2 stroke oils are diluted with a "thinner oil" for various and obvious reasons. Such as pump flow during cold weather. Such minor dilution (generally less than 10%) does not affect performance. In addition, the dilutant is often a lubricant.
I just cannot understand this kind of logic! Why not run pure oil in your car for instance. Diluting motor oil with extreme pressure compounds, anti foam additives, detergents, anti wear compounds, viscosity index improvers and the like just dilute the base oil. Therefore pure oil would be better (NOT).
Well made 2 stroke oil is an enginnered product designed to do a particular job.
32 to 1 is a level of lubrication tested snd proven to perform in nearly all conditions. That is why race bike manufacturers generrally recommend that ratio. Of course, the EPA would like you to use less oil.
50 to 1 is a level of lubrication tested and proven to perform in applicaitons that have slightly less load, such as low powered engines and low stress engines such as outboards.
Once again, RPM is a key factor in engine load, in addition to ulitmate output. Consider piston speed to be the load factor. A good guess of low piston speeds would be anything under 3000 feet per minute.
Chris
Chris
