I have a Harbor Freight meter that had one of its leads pull out of its probe. They don't use common type plugs for their leads so I gotta do some research to find out where I can get replacement leads.
Originally Posted By: dishdude
Originally Posted By: maverickfhs
Originally Posted By: ZeeOSix
I think I have 1/2 dozen of those free HF multi-meters. All still working except one that I smoked the Ohms function on by putting 115 VAC across it.
Still works on all the other functions though.
That's hilarious! Lol
Now I want to try it. lol
That's why those cheap meters can be very dangerous. That is one way to cause an arc flash explosion, since they have zero protection from that hazard. Do not get near your electrical panel with one of those.
https://video.search.yahoo.com/search/video;_ylt=A0LEVzDP1SdaTVsAmJRXNyoA;_ylu=X3oDMTEyaTZxcnFtBGNvbG8DYmYxBHBvcwMxBHZ0aWQDQjQ4NThfMQRzZWMDc2M-?p=arc+flash+from+cheap+multimeter&fr=yfp-t#id=3&vid=72aa38e188627b89154450a6a3cfe09c&action=view
I had to replace one of the battery leads after a battery corroded it. Thought it was just a bad battery too at first. They have a screw for calibration that you can set it to a good known meter reading.
I didn't get an "explosion" per say ... when I said "smoked" I just meant the Ohms function stopped working after probing a wall outlet with it still on the Ohms setting.
