It is not true that track driven cars do not suffer from the problem. They do. Also, it's not due to low RPM use. It's due to high RPM inertial loads on the rods and rod bearings. The very high RPM's these engines turn places incredible stress on both the connecting rods and rod bearings. The loads far exceed the type of loads a rod and it's bearing might experience from, say, a turbocharged engine turning lower RPM and making more HP.
Those that dig deeper into this problem are also finding connecting rod stretch and bearing bore distortion.
I don't believe oil will fix the problem, although tougher bearings will help. The solution to the problem very likely includes lower reciprocating mass. Manufacturers that build successful high RPM engines universally use very light pistons. Even a seemingly minor reciprocating mass savings yields large improvements.
An example of a light weight piston:
It's unfortunate, but the proper course of action includes changing rod bearings before they wear out.
