Cream-like oil in my bike, the cause?
by dole
04/23/18 01:54 PM
ATP At-216 Synthetic atf
by RdSnake
04/23/18 12:25 PM
Mann-Filter HU 711/51 X (cartridge) C&P
by 1JZ_E46
04/23/18 12:24 PM
Pennzoil Warranty
by Isophix
04/23/18 12:08 PM
buying oil.. question
by Dymblos
04/23/18 11:40 AM
Recommend me a UV light for AC dye leak detection
by zzyzzx
04/23/18 11:32 AM
2004 Toyota Sienna overheating
by Rtstrider
04/23/18 11:29 AM
Milesyn SB 10W30 API GF-5/SN, Synthetic Blend ?
by Quickman28
04/23/18 11:28 AM
Looking at a Hybrids as the main Family Hauler
by FutureDoc
04/23/18 10:54 AM
naturally aspirated cars left?
by flinter
04/23/18 10:31 AM
1989 Mercedes 300E
by jxthomps
04/23/18 10:07 AM
Just what we need, another Redline 5w30 VOA
by UG_Passat
04/23/18 09:54 AM
Electric Pressure Washer Recomendations
by Egg_Head
04/23/18 09:50 AM
VW Jetta 5 cylinder cartridge oil filter
by troyken
04/23/18 09:48 AM
Mailing in to Blackstone?
by 07titan
04/23/18 09:43 AM
Cameras With Film
by BlueOvalFitter
04/23/18 09:29 AM
Dipstick Tube on 4.6L
by Ifixyawata
04/23/18 08:48 AM
Starting Issues
by coopns
04/23/18 08:48 AM
3D pistons
by supton
04/23/18 08:39 AM
Replaced the high pressure fuel pump on my GTI
by skyactiv
04/23/18 08:08 AM
BradPeterson, daylateetc, Kjammer, sonnyk, PWMDMD
64821 Registered Users
86 registered (2015_PSD, ArrestMeRedZ, 2010Civic, 1WildPig, 1JZ_E46, askani79705, 7 invisible), 1785 Guests and 43 Spiders online.
64821 Members
68 Forums
282191 Topics
Page 1 of 2 1 2 >
#4541166 - 10/12/17 01:06 PM Newer GM 6.2L Ecotec motor oil choice
Balrog006 Offline
Loc: West Michigan
Friend just picked up a Yukon Denali, MY 15 I think and we were discussing his upcoming maintenance items and his plans.
His other POV is a Ford SD Diesel so he was seeking advise in what oil to use for the new motor in his life. I hadn't seen much on it and said I'd look some for him, well after some searching I still can't find much.
It's spec'ed for 8 qts of 0w20Dexos, I'd originally thought that since Dexos2 is a thing now that picking off that list would be a good start, but there are no 0 or 5w20's on it currently. Dexos2 list
Is there anyone out there with first hand or relevant knowledge and advise on what oil to pick? Perhaps some UOA's? I looked here as well but didn't see much of anything.
Thanks in advance to anyone providing useful insight based on facts and experience.
06 MDX 211K+ P Plat 0w20, A01
08 CRV 271K+ VSyn w/ML, A01
04 JD L130 720H, Mobil S 5w30
13 JD 2032r 300H, JD Plus 50 ii 15w40
M1Delvac 5w40 in OPE
#4541180 - 10/12/17 01:14 PM Re: Newer GM 6.2L Ecotec motor oil choice [Re: Balrog006]
oil_film_movies Offline
Loc: MN
The dexos2 list you are looking at is for diesel engines only.
You want dexos1 Gen2 oil, of which you can use any dexos1 Gen2 0w20 at walmart, or you can use dexos1 Gen1 Mobil1 oils. I have a GM 2018 vehicle that uses 0w20 and it says the old generation of dexos1 Gen1 Mobil1 oils are OK to use too, so if you see old stock Mobil1 oils on the shelf, they are OK to buy.
If you mail order dexos1 oil say from Amazon.com for example, right now they might just send you dexos1 Gen1 oil, so be careful there.
The reason you probably want dexos1 Gen2 oil is that its been tested to be a little better than the last generation. Timing chain wear, an extra oxidation test, and LSPI tests. So the latest generation is a little better if you can find it, which is quite easy on the shelf, just look for the words "Gen2" on the front logo label.
Edited by oil_film_movies (10/12/17 01:18 PM)
#4541196 - 10/12/17 01:32 PM Re: Newer GM 6.2L Ecotec motor oil choice [Re: oil_film_movies]
Balrog006 Offline
Loc: West Michigan
Thanks for pointing out the Diesel list, it seemed a little off but I couldn't put my finger on it-strange how it was the top and only result to the list that popped up on google.
If I replace Walmart from your reply with Meijer ( we are Meijer friendly folks, not so with WM) that is exactly what he and I both plan on doing for our oil supplies.
While I don't disagree with the sentiment of the rest of your post and advice, I'd still really like some first hand experience or some actual UOA's to back up any opinions given.
#4541203 - 10/12/17 01:37 PM Re: Newer GM 6.2L Ecotec motor oil choice [Re: Balrog006]
ARCOgraphite Offline
Loc: N.H, U.S.A.
6.2L + ECOTEC + on a Yukon - that's funny!
Sorry I have nothing to add
Oil will be way understressed, you could likely run, gasp Motorcraft 5w20 in there smile
Do these blocks use a canister system now?
2014 Nissan Rogue S CVT, OC#9 41392mi-QSUD10W30 + M110A CHAMP Filter; 2017 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
#4541218 - 10/12/17 01:50 PM Re: Newer GM 6.2L Ecotec motor oil choice [Re: Balrog006]
Loc: MN
https://www.blackstone-labs.com/Newsletters/Gas-Diesel/July-1-2017.php is the only real basic study of iron wear rates I know of. And they basically concluded there is no real difference between name-brand oils on iron wear rates.
The info on bitog is spotty and not enough to draw conclusions.
One big thing that UOA's don't tell you: Piston deposits. Pennzoil has claimed they do very well on limiting the black stuff that collects on pistons. If they are correct, then stick with Pennzoil synthetic 0w20. Note piston deposits are invisible to owners and UOA's alike. But of course Pennzoil didn't compare its oils to the top oils like Mobil1 Extended Performance and Mobil1 Annual Protection. If you're looking for the best stuff, the Mobil1 Annual Protection is the latest technology from Exxon-Mobil, so its a good bet.
Fram Ultra oil filters are very hard to beat.
Edited by oil_film_movies (10/12/17 01:51 PM)
#4541482 - 10/12/17 07:12 PM Re: Newer GM 6.2L Ecotec motor oil choice [Re: Balrog006]
askani79705 Online   content
Loc: midland tx
2017 Ford F150 NAPA syn 5w30 Fram 11955.
2000 Chevy 2500 Silverado PYB 5w30 AC Delco Filter
#4541547 - 10/12/17 08:14 PM Re: Newer GM 6.2L Ecotec motor oil choice [Re: askani79705]
Balrog006 Offline
Loc: West Michigan
I can get 5qt jugs of 0w20 Dexos approved oils for what a single quart of that runs...
#4541550 - 10/12/17 08:16 PM Re: Newer GM 6.2L Ecotec motor oil choice [Re: ARCOgraphite]
Balrog006 Offline
Loc: West Michigan
Funny-HaHa or funny Strange? Guess I don't get it...
Canister as in the type on top of the motor where you just change the element? No
#4541677 - 10/12/17 09:55 PM Re: Newer GM 6.2L Ecotec motor oil choice [Re: Balrog006]
Loc: midland tx
5 qt jug for $5.85 ? I thought I was doing well with the milesyn deal awhile back, please share !
#4541820 - 10/13/17 05:34 AM Re: Newer GM 6.2L Ecotec motor oil choice [Re: Balrog006]
NH73 Offline
Loc: Pa, USA
It seems there are many people confused between DEXOS 2 and DEXOS 1 GEN 2.
#4542257 - 10/13/17 02:59 PM Re: Newer GM 6.2L Ecotec motor oil choice [Re: NH73]
Garak Offline
Loc: Regina, Saskatchewan, Canada
If they're confused here, just imagine it in the real world at the parts counter or elsewhere in retail. wink
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
#4545410 - 10/16/17 06:27 PM Re: Newer GM 6.2L Ecotec motor oil choice [Re: askani79705]
Balrog006 Offline
Loc: West Michigan
PUP
QS
Edited by Balrog006 (10/16/17 06:34 PM)
#4545638 - 10/16/17 09:35 PM Re: Newer GM 6.2L Ecotec motor oil choice [Re: Balrog006]
Indydriver Offline
Loc: Indiana
They're specing 0W-20 in GM V8s now?!? Ecotech LOL.
I have a 2014 MY 6.2 LS3 that specs 5W-30 on the road and 15W-50 on the track. I let the dealer do four free oil changes and they used AC Delco brand semi-syn. Since I started doing them, it gets M1 and Wix filters.
My 2007 5.3 is the junkyard dog. It uses up all my leftovers, conventional, synthetic, 0W-30, 5W-30, 0W-40 and goes 8,000 mile intervals. I use M1 High mileage 5W-30 and Wix when I want to be nice to it. (This is the Tahoe BTW).
I will never use 0W-20 in my GM V8s. The takeaway for you is, you can put just about anything slippery in there and it will work. Pick a weight and brand you're comfortable with, one that is readily available and competitively priced and go.
Edited by Indydriver (10/16/17 09:39 PM)
2017 Mazda CX3 1000 FF
2014 Camaro 2SS/RS LS3 Vert 13,000 M1
2012 Sienna 75,000 M1
2011 Accord VCMV6 75,000 M1
2007 Tahoe 130,000 M1 HM
#4545680 - 10/16/17 10:23 PM Re: Newer GM 6.2L Ecotec motor oil choice [Re: Balrog006]
RhondaHonda Offline
Loc: MO
I dumped the factory fill at 1500 miles in favor of Mobil 1 Extended Performance in my wife's 2017 Yukon XL 6.2. Ran that down to 4% on the OLM which looks to be set for 7,500 mile oil changes and had the dealer change it for free. Not much other info at this point but I'll do an oil analysis once I'm done with the free oil changes.
#4545681 - 10/16/17 10:24 PM Re: Newer GM 6.2L Ecotec motor oil choice [Re: Balrog006]
evois Offline
Loc: AR
The newer 6.2 of GM has AFM. Better use ONLY synthetic or Mobil 1 and you will not regret it.
Page 1 of 2 1 2 >
