Smart charges/time
by Duffyjr. 12/13/18 08:24 AM
7.3 powerstroke water pump
by mobilaltima. 12/13/18 07:10 AM
98 Jeep Cherokee, what oil is spec'd?
by otis24. 12/13/18 06:31 AM
fixing LED Christmas lights
by danez_yoda. 12/13/18 06:30 AM
Things are not as they seem to be..
by CourierDriver. 12/13/18 06:09 AM
Oz Ranger Raptor
by Shannow. 12/13/18 05:22 AM
Shop vac recommendations
by dlundblad. 12/13/18 05:06 AM
Internet Network Issues
by ZeeOSix. 12/13/18 04:13 AM
Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Exhaust fumes in cabin
by Skater4life27. 12/12/18 08:40 PM
Squeaky sunroof
by dishdude. 12/12/18 08:09 PM
Liqui Moly Top Tec 1800
by Chuckh. 12/12/18 07:56 PM
2006 Pathfinder Transmission Shudder
by Bluestream. 12/12/18 07:10 PM
Maybe E-10 is better? - PentaStar (Flex Fuel)
by StevieC. 12/12/18 06:52 PM
Shipping cost
by Fitter30. 12/12/18 06:45 PM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
91 registered members (aquariuscsm, A310, atikovi, 4WD, aba4430, 11 invisible), 1,783 guests, and 43 spiders.
Topics295,012
Posts4,926,000
Members66,664
Most Online2,553
Oct 27th, 2018
Knock sensor scanner readings #4518216
09/16/17 08:47 PM
09/16/17 08:47 PM
West Michigan
buck91 Offline OP
buck91  Offline OP
West Michigan
So I picked up the Forscan app to augment/replace Torque on my bluetooth reader/phone setup. Nice program. Anyways wanted to watch a few things.
F150: Misfires, pinging, trans temp
Explorer: PTU and trans temps
Noticed that while the Explorer was in the <100 range for the knock sensor values my F150 was in the 400-500 range. For those familiar with Ford and/or Forscan what is a desirable range? I know there is many differences between my NA 5.0L in the truck and the EB3.5L in the Explorer but they are basically both all aluminum mills. Besides, I'd expect the turbo engine to ping more than the NA...
Not really sure where to take this. Truck is fine on power and fuel economy, though always a bit on the thirsty end of the scale. Mostly just some NVH stuff (which I have narrowed to a separate issue 99% of the time).
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Knock sensor scanner readings [Re: buck91] #4518251
09/16/17 09:46 PM
09/16/17 09:46 PM
New England
gathermewool Offline
New England
I'm not familiar with what the data is telling you. Is it number of events that the knock sensor is sensing? If so, then it might be almost worthless data, if it's pre-processing by the ECM. It could be phantom knock or noise that is filtered out by the ECM and not true knock.
Do you have the ability to see feedback knock correction (real time) and/or fine knock learning (long-term correction due to repeated knock events at specific load/RPM values)?
FKC and FKL, along with fuel trims (short and long-term) are the things I'd be looking at most to give you a heads up on the most common issues, such as fuel, leaks, etc.
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Edge 0W-20 + FU filter (40,803 miles)
Re: Knock sensor scanner readings [Re: buck91] #4523390
09/22/17 04:22 PM
09/22/17 04:22 PM
West Michigan
buck91 Offline OP
buck91  Offline OP
West Michigan
I'm not really sure, still learning to use Forscan. Its a very robust program which goes above (way above) my head at this time!
2011 F150 4x4 5.0L
Re: Knock sensor scanner readings [Re: buck91] #4523875
09/23/17 09:13 AM
09/23/17 09:13 AM
ND
gonefishing Offline
gonefishing  Offline
ND
I don't have a Ecoboost (or a Ford for that matter) but came across this article that may help you out: http://stratifiedauto.com/blog/knock-retard-kr-explained/
2014 GMC Sierra 1500 SLT All-Terrain 5.3 4x4
