Originally Posted By: Reddy45
Update.
I decided to go buy the vermouth and gin to try making my own Martini at home. I figured I could mess around with the ratio to see what I liked. I used Bombay Sapphire for the gin. Martini Rossi for the vermouth. I got both the dry and sweet versions. It turns out I actually like vermouth. So in my case, I would want up to a 1:1 ratio of vermouth to gin. So in the future, if I am at a bar, it shouldn't be a problem to ask the bartender to make a "martini" with a 1:1 ratio right?
You are correct. I believe that sweet vermouth makes a "legitimate" martini, too. Martini bars were a thing around here in the 90s and they really stretched the definition of "martini" (chocolate martini, anyone?). Vermouth is flavored, fortified wine. If you like vermouth, the brand and type you use WILL make a big difference in your drink. I've seen multiple web sites with vermouth reviews, a few of which might be worth your time. Bombay Sapphire is a solid gin and will probably make a decent martini, though, I think the regular version of Bombay might work better. Taste is very individual, but I think a more savory gin (think juniper, licorice root, and angelica heavy gins) makes for a good martini. Overall, it's a very trial-and-error process. I would probably not have much luck moving a home recipe to a bar because most bars do not carry a wide assortment of gins and my favorites are very unlikely to be offered.
