Originally Posted By: georgemiller
Hold-down clamp is about 3 - 4 inches away from battery terminal.
No, it's the part of the hold-down clamp that has an L-shaped cross section grabbing the edge of the battery. You're supposed to position it near the middle, away from the positive terminal. It was right underneath the positive terminal. The terminal cap doesn't insulate the bottom of the terminal and that naked bottom was sitting right on top of that grounded L-shaped metal, waiting for the disaster to happen.
Looking at my Corolla, those L-shaped pieces are very short in my case. Therefore, there is no chance of them touching the terminals. Note that the battery in the picture is a Walmart EverStart Maxx 24F South.
I'm surprised that the L-shaped pieces are so long in your case. Do you have an aftermarket hold-down clamp? That could be your problem right there. In any case that L-shaped piece shouldn't be that close to the positive terminal let alone sit directly underneath it. Check it ASAP and correct it if necessary before the same disaster strikes again.
That engine is so dirty it makes me itch. If that car were mine, I would never open the hood with anyone around.
