Originally Posted By: Shannow
Originally Posted By: dnewton3
Further; this:
http://papers.sae.org/2007-01-4133/
The TCB (tribochemical barrier) develops in the first few thousand miles. As it matures, wear rates actually drop on a magnitude of about 10x, despite any/all manner of use. Short trips, long idles, steady state; it does not matter.
That paper specifically took a bunch of oils, some of which were completely totalled as in having thickened well out of grade and TBN, and measured the development of a tribofilm under test conditions of metal on metal with new and used oil.
The study, as we have been over, and over, and over, and over...does not in any shape or form demonstrate that which you keep attributing to it.
Did the three lubes thicken? Yes.
Did TAN cross over TBN? Yes.
So what? Other than stating the obvious, what effect was there? You're bringing up points that essentially have no merit other than as a diversion tactic.
The point I make is salient and it exactly what they make of it too; wear rates drop as the oil matures because of the TCB. Once the TCB is established, the wear goes down. The TCB is established generally in the first few thousand miles, and the wear rates drop after that is formed. But the acid cross over, and oil vis increase, do not correlate to any of the wear trend data. Once again, your constant objections to the usefulness of the study are moot and based on a false sense of purpose.
Allow me to quote from the study:
It is interesting to note the viscosity of the 7500 mile drain oil is about 20% higher (at 100c) than that of the 3000 mile drain oil and therefore, might be expected to show a lower wear rate because of increased oil film and the resulting reduction in asperity contact. But both oils showed similar wear rates indicating that the wear rate is controlled more by the chemistry of the surface film at the contact than asperity contacts."
IOW, for those of you whom don't understand what you read ... the wear rates were unaffected by the viscosity change. Because there is no correlation, there can be no causation.
The lube thickened and the acid flipped, and it made absolutely no difference in wear rates. I am at a loss to understand why you bring those two topics in from the periphery, as if they matter. Sir - they don't matter and that very point is directly addressed in the study.
What did change that precipitated the wear reduction? The development (thickness) of the tribochemical barrier.
Their conclusion (and mine) is valid; the TCB is the majority controller of wear rate reductions.
And this phenomenon is echoed in my UOA data research and analysis. There are lubes that will thicken from oxidation, but not all will. Specifically, PAOs don't thicken much; that's part of their benefit. And yet the wear rates will change in the PAO OCI duration, just as with other lubes that do thicken. It's not just these three lubes in the SAE study. No - it's generally ALL lubes in ALL engines that show this affect. There are tons of UOAs that show no thickening whatsoever and the wear rates drop with the OCI. There are other UOAs that show a significant shift in vis, and yet the wear rates do the very same thing. This is a phenomenon that is NOT, none whatsoever, explained by vis and crossover.
Why you cannot understand this, when they point it out directly, is beyond me.
