My car is a 2002 Acura RSX with 195kmi and most of it's life was spent in a mild climate. I used conventional Havoline and Chevron mostly and oil analysis showed excellent results with these. I then moved to Idaho where the winters are very harsh and decided to use synthetic but didn't want to spend much money because my car had >150kmi. After more than a year of use, my engine developed oil leaks. I had great difficulty determining the source of the leaking because all the seals seemed to leak. I changed the vtech solenoid seal, and that helped, but the leaking continued from other seals.
Next oil change I used Valvoline Maxlife Durablend 5w-20, which is supposed to help old seals, and noticed no difference at first. However, the leaking slowed markedly after about a year of use. After about 18 months, I no longer drip oil on cardboard that I put underneath my car. Long story short: I'm convinced that the Supertech synthetic caused oil seal leaking after long term use (>1 year) and the Valvoline Maxlife greatly slowed or stopped the leaking after more than 1 year of use. Anybody have a similar experience?
