Worn cam lobe symptoms
by NICAT
04/23/18 02:19 AM
White car..has white grease
by Vdubuk
04/23/18 02:17 AM
Do you need to change oil if your engine leaks
by Vdubuk
04/23/18 01:35 AM
Castrol Edge 5w30 A3/B4 SCA sale 23-24 April $29
by KL31
04/22/18 10:50 PM
Testing the "oil goes bad with age" theory
by Atomic
04/22/18 09:12 PM
08 Grand Caravan with 156k. ignition problem
by Mark72
04/22/18 09:12 PM
DexOS in a 2005 Cavalier LS?
by GMWeber
04/22/18 09:10 PM
US-Canada mail transit questions..
by earlyre
04/22/18 09:10 PM
hybrid ICE wear
by tigrpal
04/22/18 08:51 PM
03' 2.3 Ford Focus / Dash light on steadly
by Oregoonian
04/22/18 08:47 PM
Tundra vibration
by pda1122
04/22/18 08:39 PM
Who says Corvettes are gas guzzlers?
by Patman
04/22/18 08:26 PM
Mobile rebate question
by Snowball
04/22/18 08:25 PM
Oil shear and 0w,5w,10w?
by Camprunner
04/22/18 05:42 PM
Looks like the Jeep needs axle bearings
by Nick1994
04/22/18 05:13 PM
Toyota OEM Cartridge Filter, Cut Open 12,669 Miles
by Nick1994
04/22/18 04:53 PM
S/C Range Rover, 5000kms 33 different oils UOA
by Vladiator
04/22/18 04:24 PM
Buying oil on price - Pricing Rant
by JHZR2
04/22/18 04:22 PM
Mix of 33 oils VOA
by Vladiator
04/22/18 04:19 PM
Sugar Binge Hangover ... :~/
by LoneRanger
04/22/18 04:18 PM
daylateetc, Kjammer, sonnyk, PWMDMD, usernameunknown
64820 Registered Users
16 registered (Duke, FowVay, edyvw, Billbert, csandste, BlueOvalFitter, 2 invisible), 645 Guests and 51 Spiders online.
64820 Members
68 Forums
282164 Topics
Page 1 of 3 1 2 3 >
#4408871 - 05/19/17 04:22 PM Let's All Point and Laugh at the OP
Speedie95 Offline
Loc: Rhode Island
Your Friday opportunity to have some fun at my expense grin
The story starts with a Champion 5,000 watt generator that I've had for a while. I'm in the habit of running it for 20-30 minutes every month or so to prevent fuel system problems. A couple of weekends ago I went to start it up and it ran for 4-5 seconds and died. Hmmmmm. Wouldn't start up again.
Suspecting a gunked up carb, I put some seafoam in the tank and gave it a quick burst of starter fluid through the air intake. It started up alright, and promptly puked gasoline everywhere then started shooting flames out of the air intake. Ooooops. I will say that the gazelle-like speed and grace with which I dashed for a fire extinguisher and put the flames out was pretty [censored] impressive.
(At this point I will also say well done to Champion as the flames were right next to the carb / main fuel line / gas tank, and nothing really bad happened).
With the carb now a mess of melted plastic parts and full of fire extinguisher powder, and the air intake just a melted mess, I had to order new parts. They arrived, I put everything back together, and tried to start it. Once again, it puked gas everywhere. No fire though so yay! Progress.
This time I was a lot more thorough in my inspection, and noted that the brand new carb was dry as a bone on the exterior. The air intake however was soaked in gas. Hmmmmmm. I removed the plug and gently turned the engine over using the starter rope. With the air intake cover open, I could now see that the gas was pouring out of the breather tube. [censored]. Im not Ace Ventura Engine Mechanic, but I know that the engine shouldn't be spewing up gas through its breather tube.
Opened up the oil fill and I was greeted by gas pouring out of the crankcase. Oh boy. Had a brainwave (about the only one in this whole sorry story) and checked the fuel shutoff valve by pulling the fuel line from it. Yup. It had failed, and even in the "Off" position it was letting gas pour through. Sigh.
Drained the fuel tank and replaced the shutoff valve with a spare. Checked for function. Drained the crankcase and filled it with fresh oil. Checked the plug which was of course a fouled mess, and replaced that too.
Fuel: check. Air: check. Spark: check. Oil: check.
It was at this point that I hoped, as you might be doing, for a happy ending to this story. Turned the fuel on, turned the ignition on, set the choke, pulled the starter rope and...
...the ^&[email protected] rope snapped in half.
Having let loose a stream of profanity that would make a Drill Instructor blush, I took the recoil starter assembly off. Replaced the rope, tried to wind tension into the spring, and was greeted with the click click click of doom. Fabulous. Disassembled the pulley and was greeted by the recoil spring unwinding itself all over the floor. If you've ever tried to rewind one, you'll know how much fun the next half hour of my life was.
I finally got the [censored] thing working again, reassembled the pulley, went to wind tension onto the spring, and yup, you guessed it, click click click. Somewhere in the reassembly process the spring had unhooked itself from the pulley.
You know what happened next, right? If you guessed "as you hooked it back up to the pulley it unwound itself again from the other end" then go to the top of the class. No profanity this time, just a sigh of resignation as I set to rewinding the spring. Again.
The story does end well as, having wrestled the spring into submission one last time, I was able to keep tension on it while I wound the new rope onto the pulley. Reattached the assembly to the generator, and it started first pull.
For all of the abuse, especially an engine drowned in gasoline, it merely smoked like a stoner at Reggaefest for 2-3 minutes and then began to purr like a kitten. Let it run for a while and not so much as a hiccup. Perfect 220v output. Ahhhhhhhh. The sweet smell of success.
Go ahead, give me your worst about all the signs that I missed along the way. You can't possibly give me any more [censored] than I've given myself grin
#4408875 - 05/19/17 04:27 PM Re: Let's All Point and Laugh at the OP [Re: Speedie95]
901Memphis Offline
Loc: Northern Kentucky
Nice story
2012 Chevy Cruze LT 1.4T - 50k
2002 Buick Century 130k - Built 4T65e(Maxlife) - Edge 0w40 + Fram XG3980
#4408876 - 05/19/17 04:29 PM Re: Let's All Point and Laugh at the OP [Re: Speedie95]
NormanBuntz Offline
Loc: Outer Banks, NC
You have more patience than most of us.
"What is it, the first hole I dug?"
2017 Honda Odyssey SE
2013 Honda Accord LX
2007 Honda Ridgeline RTS
2007 Infiniti M35
#4408877 - 05/19/17 04:32 PM Re: Let's All Point and Laugh at the OP [Re: NormanBuntz]
tgrudzin Offline
Loc: Chicagoland, IL
I laughed. Thanks for sharing.
#4408888 - 05/19/17 04:52 PM Re: Let's All Point and Laugh at the OP [Re: Speedie95]
oldhp Offline
Loc: USA
Been there...done that when nothing and I mean nothing would go together, run, lost the part, wrong trans filter(store closed)...you get my drift. I would suggest a stainless steel ball valve to shut off the fuel to prevent BP rising in the future. cheers
#4408889 - 05/19/17 04:54 PM Re: Let's All Point and Laugh at the OP [Re: Speedie95]
pandus13 Offline
Loc: Chicago,IL,USA
you lived up to your name!
Nice recovery!
16 Golf SportWagen
13 Mazda5
08 Yaris
04 Elantra
95 accent
95 mystique
97 concorde
#4408891 - 05/19/17 04:57 PM Re: Let's All Point and Laugh at the OP [Re: Speedie95]
yvon_la Offline
Loc: quebec canada
Hahaha,I had Kawasaki minitrail 49cc a few decade back .i had forgotten the gas valve open and didn't pay attention to it .it didn't want to start .the mechanic tell me , it's probably in thevalve train. I'm like what?.I told him just change the oil and spark plug .that fixed the issue . He then told me that a lot of gas had ended up In the oil pan
Don't we love basic stuff like this happening.yep I was like ,dam I m stupid.hahaha
Truck driver
Nissan versa note s 2014 total classic 5w30(qc.ca) drivework oil filter
#4408892 - 05/19/17 04:57 PM Re: Let's All Point and Laugh at the OP [Re: Speedie95]
RichardS Offline
Loc: Melbourne, Florida
If you think a stoner at Reggae fest smokes, you've never been to Hippy Hill on 4/20, AT 4:20pm.
You'd get high from 20 blocks away.
Also, thank you for the laugh!
2008 Dodge Caliber SE 2.0 117k
4qt Imeditsu 0w-20, 1/2qt Mobil SS 5w-20 Fram HM
2003 Buick Century 107k
4.5q Havoline 5w-30 HM Fram XG
#4408908 - 05/19/17 05:17 PM Re: Let's All Point and Laugh at the OP [Re: Speedie95]
Bud Offline
Loc: Texas
Great story. Glad it wasn't me.
2016 Honda Pilot EX-L with NAV.....Mobil 1 0w20 AFE and Ultra XG7317
#4408916 - 05/19/17 05:30 PM Re: Let's All Point and Laugh at the OP [Re: Speedie95]
Ifixyawata Offline
Loc: NE Ohio
TL;DR, but LOLOLOLOL anyway grin
Ok, did read now. I would think that maybe I wasn't supposed to have OPE if I were you.
Edited by Ifixyawata (05/19/17 05:33 PM)
2004 Mercury Mountaineer 4.6 Mobil Custom Blend Xw-30
2001 Ford Focus 2.0 Zetec Pennzoil Euro L 5w-30
#4408918 - 05/19/17 05:31 PM Re: Let's All Point and Laugh at the OP [Re: Speedie95]
fdcg27 Offline
Loc: OH
You have to love it when a simple issue results in all sorts of what would have been unnecessary work.
This is a mistake you'll never make again with any small engine.
17 Forester 12K MSS 0W-20
12 Accord LX 86K PP 5W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
#4408921 - 05/19/17 05:33 PM Re: Let's All Point and Laugh at the OP [Re: oldhp]
Speedie95 Offline
Loc: Rhode Island
It's remarkable how parts "know" what time the local stores close and plan their failures for 10 minutes before closing time when the store is a 12 minute drive away. And yes, a ball valve is in its very near term future. The non-serviceable flimsy petcocks are a disaster waiting to happen on a piece of equipment that by definition will only be needed in an emergency cheers
#4408945 - 05/19/17 06:06 PM Re: Let's All Point and Laugh at the OP [Re: Speedie95]
andyd Offline
Loc: Marshfield , MA
Believe me. I'm laughing with you. I generally screw up the first attempt. Sometimes I'm still messing up, but not as badly, after several tries. I take comfort in the fact I'm not alone grin2
'16 Camry SE, Valvoline bulk 0w20 and ? filter
#4408947 - 05/19/17 06:15 PM Re: Let's All Point and Laugh at the OP [Re: Speedie95]
Kamele0N Offline
Loc: Slovenia
laugh laugh laugh Been there....done that.....!"#$%&/()=?* laugh
Here I usually go on a cold beer or 2,3,4 (usually with my father)....and after that things go as planned in first attempt wink
2011 Hyundai i30 1.4 CVVT Shell Helix Ultra 5w40
1997 Toyota Landcruiser KZJ95 3.0 TD various 10w40
#4408948 - 05/19/17 06:15 PM Re: Let's All Point and Laugh at the OP [Re: Speedie95]
Donald Offline
Loc: Upstate NY
A marine mechanic was starting up my Mercruiser for the first time this spring. I outside the boat and was watching for exhaust water coming out of the prop hub and the exhaust bellows.
Then I saw water (I thought) coming out of the bilge drain which would mean there was some kind of leak in the engine and it was draining into the bilge.
Told the mechanic and he quickly looked at the engine and bilge and realized he had stepped on the electric fuel pump and popped off a gas hose. The electric fuel pump was pumping gas into the bilge and it was draining out the bilge drain hole.
Yikes, things could have gone bad quickly had a spark occurred.
2015 Ford F250 w/Powerstroke
Page 1 of 3 1 2 3 >
